04-27-2020, 11:23 AM | #1 |
Drives: 2011 camaro 2 SS Join Date: Jun 2019
What trans do i have, How to check fluid ?
Got a 2011 Camaro SS L99 Auto. Curious what tranny is in it also how do i check the fluid, no dipstick that i can see :
04-27-2020, 11:58 AM | #2 |
Drives: 2012 Camaro SS Join Date: Dec 2019
There is no dipstick from the factory it’s a sealed transmission. There is a fill plug you have to see from under the car. JRE sells a dipstick mod for our cars so it could have a dipstick. I just have my local transmission Shop do it they charged $100 for labor and they changed the fluid and filter supplied.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
04-27-2020, 12:25 PM | #3 |
Drives: 2011 2SS, 2006 GMC Sierra Join Date: Jul 2019
special tools neded
buy the dipstick from JRE save you money in the long run. $80 |
04-27-2020, 01:44 PM | #4 |
376 cubic inches of fun
For a 2011 that you bought used, probably time to change the trans fluid and filter.
But after that, there's really no need for a dipstick. If there are no leaks, the fluid level won't go down for years. |
04-27-2020, 01:53 PM | #5 |
Drives: 2SS RS ABM A6 Join Date: Jun 2010
You have the 6L80E.
Contrary to the above, you don't need anything special to check it the way that GM intended. There should be a sticker on the pan outlining this, but I'm trying my best to do it from memory. Park on a perfectly level spot. Warm up the car until the transmission fluid gets to 130 degrees F (and there's an upper threshold like 175). There's a thing that people mistake for drain plug. Put a shallow container under that and crack open the drain plug looking thing. When you remove it, there should be a small, steady stream of tranny fluid. Put the plug back in it -- it's filled right. No fluid? -- probably need to add some (to to fill plug) Pouring out like crazy? -- probably overfilled.
Jack Bilger
04-27-2020, 04:53 PM | #6 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
This is right out of Chilton manual. Make sure it is level, difficult to do on jacks but maybe use a hardware store level if you're meticulous. Basically "fill to spill" using factory plugs. A dipstick is a nice convenience MOD. Wish they made one for my V6 car.
04-27-2020, 06:18 PM | #7 | |
Drives: 2010 Camaro 2ss Join Date: Mar 2018
Here’s the GM procedure, stolen from another thread. It is vital that the car is level! |
04-27-2020, 06:54 PM | #8 |
Drives: 2011 1SS/RS IBM Camaro Join Date: Jan 2011
Everyone do it the way you want. I just put the JRE dipstick in and no more problems reading the transmission fluid.
[Just Me]
04-27-2020, 08:13 PM | #9 |
That was my point. It can be done but most people don’t have a garage with a lift or 4 ramps or 4 stands and a jack to level the car off the ground to get under the car. U can’t get under these car on the ground.
04-27-2020, 09:18 PM | #10 |
I agree - best mod for $80
I will do mine some time this year probably I hate not seeing a fluid level or condition. https://jannettyracing.com/collectio...it-6l80e-6l90e
04-29-2020, 11:37 AM | #11 |
Thanks for the accurate info. You guys never disappoint
04-29-2020, 06:28 PM | #12 |
Drives: Camaro Join Date: Oct 2018
If you do change the fluid and filter get the filter made for the suv/trucks. I don’t have part number in me but hammdo has it in his build thread
04-29-2020, 07:15 PM | #13 | |
I installed it last year during a fluid change, pickup mouth is quite a bit larger than the OEM part. It comes with the seal too. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
04-29-2020, 07:32 PM | #14 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
It's a 6 speed.
