Old 03-21-2022, 08:55 PM   #1
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
Drives: Chevrolet Camaro SS
Clutch Failing
Stock clutch, squeaky tick master cylinder, tick external reservoir, 100,000 miles. Not saying anything negative about tick, my master cylinder is squeaky which may be related to the issue I describe here, or maybe not.
Going 65 on highway and kids pass me wanting me show them something. I downshift into 4th and gas it. Pedal mash revs up to 80, starts to redline, I shift into 5th and mash continues. I let off everything and the smell of burnt fluid is strong.
I am used to pedal mash when launching. But this was new.
I have been wanting a dual disc clutch for awhile, so it is easy for me to decide this summer is finally the time. BUT, is there something else going on here? I will be super pissed if I put in a $2,000 clutch kit and go out to let we rip and have pedal mash.
2014 SS LS3/LSA Supercharger, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
Valkyrie14 is offline   Reply With Quote
Old 03-22-2022, 07:39 AM   #2
gtstorey
Not sure what "pedal mash" is but typical a failed master cylinder would fail by not applying pressure to the fluid, not holding pressure but I have seen old rusty master cylinders hold pressure the plunger was stuck. I doubt that is your problem though.
By stock clutch do you mean original with 100k miles? I don't see much reason the expect anything other than a worn clutch if that is the case. If 5000 miles maybe need to look further. But even then you are well beyond stock power.
gtstorey is online now   Reply With Quote
Old 03-22-2022, 08:02 AM   #3
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
Peda mash means that the clutch pedal pulls itself to the floor and the rpm’s shoot up to 7000-7500, without the desired acceleration.
Yes, 100,000 on original clutch. The clutch has always been stiff and has always done the pedal mash when I try to launch. My launch technique is only letting rpm’s up to 3,000 before disengaging the clutch. So I followed some threads on here about that and switched to an external reservoir. When that didn’t work I went to a tick master cylinder, that also has an insulated line. That didn’t work, plus it squeaks super loud.
For normal driving the clutch works, it is just stiff and squeaky. No slipping that I notice. But what is the point of have a supercharged LS3 if every time you want to get on it the clutch mashes to the floor.
Old 03-22-2022, 08:14 AM   #4
gtstorey
I would guess your clutch is on borrowed time at 100k and increased power, but I don't have a clue about the pedal problem.
Old 03-22-2022, 08:27 AM   #5
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Lingenfelter used to sell a return spring for the pedal. The only time I had the pedal stick down was when the fluid got hot racing. That disappeared when I installed the external reservoir with the new clutch. 100k is a lot of miles on a clutch, especially if you are running it hard. Personally, I would look at it as the clutch needs replacing soon anyway so you can either run it until it fails or go ahead and do it on your schedule. Hell, it would probably be a good time to put carbon blockers and synchros in the trans along with bronze fork pads and Liberty bearing kit while it's out, then you have a fresh build going back in that is stronger than new.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, and meth. Z28 suspension.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff.
Old 03-22-2022, 08:29 AM   #6
fz4k98
Drives: 2013 1ss
I have not had a problem with pedal mash but have had two twin disk clutches and am now on a spec 3+. I really love the spec 3+ on my 13 camaro and have 610rwhp.
I spent a lot of time trying to resolve clutches that would not disengage. It appears to me that based on the way the system works the likely driver for the pedal mash issue would be the presssure plate being to weak to handle high rpm centrifigul forces.
The slave is under compression when the clutch is engaged and moves toward extension when the clutch pedal is pressed. If the pressure plate fingers flattened during high rpm, the slave would extend and the fluid draw would pull the pedal down.
fz4k98 is offline   Reply With Quote
Old 03-22-2022, 07:47 PM   #7
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
This is a good idea. I am planning on doing the clutch myself. Iím thinking rebuilding the trans may be above my ability. Is it difficult?
Old 03-22-2022, 07:50 PM   #8
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
Iím not up as high as 610, not sure of my rwhp for sure. I am looking at Monster dual with all of the upgrades. Your explanation of what is happening makes sense.
I am going to quote you when I explain to my wife why I am spending another $2K on my car.
Old 03-23-2022, 07:03 AM   #9
CamaroCracka
Originally Posted by Valkyrie14 View Post
This is a good idea. I am planning on doing the clutch myself. I’m thinking rebuilding the trans may be above my ability. Is it difficult?
I felt rebuilding the trans was more than I wanted to take on. A guy on the CorvetteForum did have a good writeup, but pulling all those gears off the output shaft did not seem like something I wanted to take on. I sent it to a local shop and gave them parts I wanted used. I even got a 9310 output shaft from RPM before they stopped selling them unless they did your rebuild.
IIRC I got the parts from here https://www.thegearbox.org/tr6060.html
Old 03-23-2022, 07:11 AM   #10
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
Nice site, thanks for the link. Considering I have no idea where any of that stuff would go I donít think I will tackle rebuilding the trans myself either.
Old 03-24-2022, 08:52 PM   #11
fz4k98
Drives: 2013 1ss
Does this mean I can quote you to my wife so she sees someone actually thinks I know what I am talking about?
Old 03-24-2022, 09:09 PM   #12
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
Seems fair.
Old 03-25-2022, 07:13 AM   #13
The_bald_eagle_machine
Anthony S
The_bald_eagle_machine's Avatar
Drives: 2011 chevrolet camaro 2ss/rs
Try this...
I do not personally have experience with this part. But Lingenfelter has a solution for the pedal mash issue that you described and they still have them in stock.
https://www.lingenfelter.com/product/L360091410.html
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181
Texas Speed 2 inch headers, high flow cats, X-pipe and Mufflers. Cold air inductions Cold air intake with JRE intake scoop mod. Tuned by Redline Motorsports. MGW Shifter. DSS One-piece 3.5" Driveshaft, BCRacing Coilovers. BMR everything.
The_bald_eagle_machine is offline   Reply With Quote
Old 03-25-2022, 07:22 AM   #14
Eastbaycamaro
Drives: 2015 2ss/rs
I will be removing my McLeod RXT twin disks next week and put it up for sale. Got about 15 passes at the drag strip. It is a solid hub design pn# 6932-07
Eastbaycamaro is offline   Reply With Quote
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
