Old 06-20-2022, 06:53 PM   #1
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
Secondary Trunk battery cable
So if you don’t know I made a thread 2 weeks ago about a no start that sounded like a bad starter. Being a GM guy and having a bunch of 70’s firebirds, novas, monte carols…. Etc….. I am used to replacing starters on my cars yearly lol. I just got my car back after being rebuilt and it was sitting for 8 months. Drove the car for the first few weeks then life happens and it sat for over a week and got a click instead of a crank. My first thought was a starter but I’ve read and peoples comments about battery or cable starting getting me thinking. I’m pretty sure my battery is weak due to sitting so long (8 months) without being started or charged I figure it’s weak and I will replace it soon. But also people where talking about adding a extra negative battery cable in the trunk. I ordered the cable in Amazon and got 2 for $12 and are good quality. I removed the body ground from the trunk and it almost broke off it was so rusted. There is no way it was a solid ground as is with how much rust there was. I cleaned up the bolt and added some dielectric grease and added the new ground cable. The car starts so much quicker and stronger now. Best mod to do and also needs to be addressed anyway due to the heavy rust that builds up on that bolt.
Will still be replacing battery this summer. Just figuring what’s a lighter weight one that would be good for a weekend driver.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 06-20-2022, 07:01 PM   #2
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
I did the same thing, ordered 2 24” 2awg wire with premade ends on them. One i put on the battery ground with the factory ground also attached. The second ground i installed it from the transmission bolt to the engine cradle subframe. It already has a threaded insert on it.
22% lower/ 2.5 upper/ 1-7/8” headers/ cat delete/ x-pipe/ AFCO with fans/ prospeed tank/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is online now   Reply With Quote
Old 06-20-2022, 07:05 PM   #3
Bigdumogre
Bigdumogre's Avatar
The second one I will place there too once I get underneath the car. Was your bolt rusted too in the trunk ?
Old 06-20-2022, 07:23 PM   #4
tartagliazl1
No rust at all. Car was a Texas car before i bought it.
Old 06-21-2022, 06:38 AM   #5
Bigdumogre
Bigdumogre's Avatar
Ahhh nice. Mine is a New York car and we see alot of salt from the winter and living on the south shore by the water even more from the ocean.
Old 06-21-2022, 08:35 AM   #6
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I did this "extra" ground cable in the trunk as well. Nice difference in startups now, especially when hot.
Old 06-24-2022, 09:23 PM   #7
Bigdumogre
Bigdumogre's Avatar
Seems to help a lot and a cheap mod
Old 06-25-2022, 08:58 AM   #8
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Yes sir! Agreed. And I haven't done the "other" ground yet, trans to frame as this one seems to have made a good difference alone.
Old 06-25-2022, 10:04 AM   #9
Bigdumogre
Bigdumogre's Avatar
I have a second one too for that but this one really made a huge difference already I may not even need it. I also see a jumper under the hood people do where the bolt jumper is. My bolt is rusted si may just clean it up and add dielectric grease like the trunk.
Old 06-25-2022, 06:02 PM   #10
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Yes sir, saw that underhood fix as well. Looked a little more intensive than I wanted to do. I also have the second cable just sitting in my parts room, probably won't ever need it, but I have it. lol.
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
