04-22-2021, 06:50 PM | #1 |
Drives: '15 1LE Join Date: May 2020
Ignition coil foiled
TLDR
Can I use a different style coil pack for my LS3 2015 camaro ss? Square to round or round to square? This thread exists, but its not very helpful: https://www.camaro5.com/forums/showthread.php?t=527694 Long story So I went to go buy a new coil pack for my 2015 camaro ss LS3. I decided to get a different style of coil pack... affectionately known as the square coil (d510c). However to my chagrin, the coil pack does not fit the connector on the wiring harness. I dunno how, but both of the AC Delco part numbers (D510C and D514a round coil) are meant for the LS3 camaro. Does anybody else have any info on this? I'm stumped as to why a particular style coil pack is fixed for a particular wiring loom connector, and even more so with the 2 different types of coil pack for the LS3/L99/(LSA?) motor. Thanks! D510C D514A Last edited by shinzzerz; 04-22-2021 at 07:25 PM. |
04-22-2021, 11:18 PM | #2 |
Hmm, I thought all of the LS3/L99 Camaros had the D510C.
And the answer to your question is...because GM. Really though, no idea why they make some of the engineering decisions they make, especially in regard to electrical connectors and cross compatibility. You would think it would be cheaper to just stay with a proven connection type. I can only assume these were different revisions based mainly around design improvements - I always thought the D514A style was an older design, but I am certainly not sure about that. If they don't make adapters for this maybe you could just swap the pigtails? But may I ask why you want to do this? I can understand if its an aesthetic thing, but if its power related, I have seen the D510C's used on 1000rwhp+ builds without issue.
04-23-2021, 11:16 AM | #3 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
I have the 510 type on mine. And yes they are easily good to 1k hp.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
