Old 03-29-2022, 02:19 AM   #1
dma05
dma05's Avatar
Drives: 2011 Camaro 2SS/RS
Differential Bushings - Drain Fluid?
I just changed my differential fluid about a month ago to Royal Purple. I now have the rear cradle out to upgrade the complete suspension and bushings.
Should I drain the differential fluid again before removing it from the rear cradle or will it stay inside while I work the old bushings out?
thanks!
Allen
2011 Camaro 2SS/RS
dma05 is offline   Reply With Quote
Old 03-29-2022, 07:39 AM   #2
NoDak1LE
NoDak1LE's Avatar
Drives: 2014 1SS 1LE
thanks!
You'll have to drain it again, working on removing the steel bushing sleeves would be a nightmare while still in the cradle.
2014 1LE Hellion Twin Turbo
804WHP / 689WTQ
NoDak1LE is offline   Reply With Quote
Old 03-29-2022, 07:50 AM   #3
gtstorey
You should be able to reuse the fluid.
gtstorey is online now   Reply With Quote
Old 03-29-2022, 08:52 AM   #4
demonspeed
Pound The Guts Out Of It
demonspeed's Avatar
Drives: 2013 1LE
^^^this
379 11:1 LS3, Wiseco Pistons, ARP Fasteners, Improved Racing Baffled Tray, Melling Pump/Retainer, LG G6X3 Cam, Johnson Link Bar Lifters, BTR Shaft Mounts/Springs/Pushrods, Powerbond Pulley, Z28 Tstat & Plugs, CPP Wires, GPI Rod Mod/Ported Manifold & TB, Vararam Intake, Kooks LTs/gutted cats, factory NPP - 490hp/440tq
demonspeed is offline   Reply With Quote
Old 03-29-2022, 09:17 AM   #5
dma05
dma05's Avatar
Thanks for the info. Draining it again today.
Allen
2011 Camaro 2SS/RS
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
