Old 04-22-2022, 11:51 AM   #1
dma05
dma05's Avatar
Drives: 2011 Camaro 2SS/RS
StabiliTrak, ABS, and Brake lights all on!
I just finished upgrading all suspension parts (front and rear) on my car and then took it to get an alignment. On the way to the shop, the StabiliTrak light came on and the engine light start flashing.
After the alignment, which was REALLY needed and Robert at Chewerks did an amazing job, the light for StabiliTrak track coming back on. Ribert reset the sensor but it’s still happening
Then about 30 mins later, the ABS and Brake light both come on. I pulled over and checked the brake system and it looks fine visually. Now I have all these lights on!
Any thoughts on what it could be? Could I use my HP Tuners to get the info on the issue(s)?
2011 Camaro 2SS M6
Thanks!
Allen
2011 Camaro 2SS/RS
dma05 is offline   Reply With Quote
Old 04-22-2022, 11:59 AM   #2
gtstorey
I don't think HP Tuners can pull anything but P(powertrain) codes. Those codes will be in other modules and will need other readers to pull them. In particular I think all of the ones you need are chassis codes.
Old 04-22-2022, 12:20 PM   #3
dma05
dma05's Avatar
I also have a SCT x4 scanner. Would that pull the codes?
Some other notes:
I did replace all the wheel bearing hubs, so those shouldn’t be the issue.
Allen
2011 Camaro 2SS/RS
Old 04-22-2022, 12:44 PM   #4
gtstorey
"I also have a SCT x4 scanner. Would that pull the codes?"
Most of the programmers only access the ECM but I don't have any experience with the SCT.
"I did replace all the wheel bearing hubs, so those shouldn’t be the issue."
I would check the wheel speed sensors/wiring. And you could have gotten a defective hub or maybe even the wrong one.
I assume the steering wheel is centered while driving now?
I think I would try and clear it one more time by disconnecting the battery and see what happens.
About the cheapest way the read correct codes for this is a TECH 2 clone.
https://www.vxdiagshop.com/wholesale...r-gm-opel.html
Old 04-22-2022, 12:47 PM   #5
dma05
dma05's Avatar
The wheel bearing hubs are the Z28 hubs. I got 4 of them and replaced each hub. This is the part number I ordered: 25954415
I’m guessing a speed sensor may be the issue, but rather guess, I would just like to pull the codes and go from there. Just need a way to do that
Allen
2011 Camaro 2SS/RS
Old 04-22-2022, 01:02 PM   #6
gtstorey
This one at Harbor Freight can read ABS codes, but I'm not sure if what you have a problem with would be considered an ABS code or is a chassis code.
https://www.harborfreight.com/automo...der-57663.html
Old 04-22-2022, 01:21 PM   #7
gtstorey
Originally Posted by adamphelps View Post
recommend vehicle review blogs please
Spam reported
Old 04-22-2022, 01:37 PM   #8
dma05
dma05's Avatar
It may be the ABS speed sensors. There were a few times they got pulled by accident and from what I’ve read, they are sensitive.
I’m picking up a scanner from Oreilly’s and also ordering new sensors since they aren’t expensive.
Allen
2011 Camaro 2SS/RS
Old 04-22-2022, 03:26 PM   #9
dma05
dma05's Avatar
I ran the scanner and I pulled two codes:
P0308: Cylinder 8 misfire
U2100-00: CAN Bus communication
Not sure why there is a misfire, but I did read this will trip the StabiliTrak system.
Allen
2011 Camaro 2SS/RS
Old 04-22-2022, 03:36 PM   #10
gtstorey
Does that scanner read chassis (C) codes?
Old 04-22-2022, 03:44 PM   #11
dma05
dma05's Avatar
No, I don’t think so.
Allen
2011 Camaro 2SS/RS
Old 04-22-2022, 03:55 PM   #12
dma05
dma05's Avatar
Found the issue!! The spark plug wire for cylinder 8 fell down onto my headers and burned. You can see the white spot in the picture. My wires route differently as I have my coils relocated. Time to make another wire and get it back on the road!
Allen
2011 Camaro 2SS/RS
Old 04-22-2022, 04:06 PM   #13
gtstorey
Maybe that will resolve all you issues I know that the misfire can trip the stabilitrak light but I don’t know about the others. It may.
Old 04-24-2022, 06:58 AM   #14
Joe.G
Joe.G's Avatar
Drives: 2014 2SS
Nice find, that scanner should be able to pull ABS Codes. If the sensors are not seated 100% they don't read right, I just went though this on my daughters car. Are the Z/28 Sensors the same as the SS? Just wondering if they need to match the hub or not.
2SS/RS 6SP GM 3.91/TrueTrac Ashen Grey OEM ZL1 Rims & Side Skirts.ACST4 Splitter/Deflectors NPP Mild To Wild,Resonator Delete, GM Short Throw,Remote Clutch reservoir
Cold Air Inductions CAI, Moroso Catch Can
Stainless Works Ceramic Coated 17/8th HiFlo Cats
SCT X4 Dynosteve
Hotckis 1" Springs and Chassis Max Brace
BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA and Z28 UCA Bushings Hendrix Solid Cradle Bushings
Pedders Radius Rod Inserts Strut tower brace
Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
