09-04-2023, 01:18 AM | #1 |
Drives: 2011 Chevrolet Camaro SS L99 AT Join Date: Oct 2021
P0336 on hot oil
I'm constantly haunted by this problem. After good driving (when I sit on the throttle pedal) car dont start correctly. I have slow cranking and Servise Stabilitrack comes on without CEL. With scanner I can see P0336 error. I have already replaced crank sensor several moth ago but issue remains.
Maked heat shield for the starter (this one), replaced negative battery wire, maked additional negative wire for the starter but nothing helps. Could it be rod bearings issue ? When I drive as usual everything is OK (even when oil temp rises up to 250F) , but when I sit on the throttle and drive in Competitive Mode, I have this problem..
2011 Chevy Camaro SS AT L99 / Stock / Daily Driver
1972 Plymouth Barracuda RB V8 3X2-barrel Holley R-4382A/R-4375A/R-4383A (Hamtramck) / Stock / Weekend Driver |
09-04-2023, 09:09 AM | #2 |
Drives: 2010 2SS/RS A6 Join Date: May 2019
-Weak or bad battery can cause those symptoms.
-Poor grounding of the engine and chassis. |
09-04-2023, 09:44 AM | #3 |
^^ This. When the battery gets old and doesn't hold a good charge these cars run like crap and cause all sorts of issues, including not wanting to run right while "in the gas". Check your battery.
09-04-2023, 12:54 PM | #4 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
+2
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
09-05-2023, 04:08 AM | #5 | |
Is there a relation between aggressive driving and subsequent poor starting and bad battery ?
09-05-2023, 08:47 AM | #6 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
I would continue to trouble shoot the DTC. If it's still popping it's still a problem. If it doesn't know the position of the crank shaft in relation to the cam, it's going to struggle to start.
09-05-2023, 09:15 AM | #7 |
09-05-2023, 02:54 PM | #8 |
Mine is a 800 CCA battery. Aggressive driving will get the engine and all components pretty warm, and after shutting down, then trying to restart it you could have the "heat soak" issue with the starter due to the bad grounding these cars have. That's why a lot of us have added additional ground cables to our cars, to stop the "hard start" issues when the starter is hot.
09-06-2023, 11:23 PM | #9 |
DTC is a consequence of the slow rotation of the crankshaft, I think so. Because there are no DTC problems with a cold and warm engine
09-06-2023, 11:31 PM | #10 | |
I made a heat shield for the starter. I have put a wire from the transmission case to the starter, sit the starter on the washer that connected to this additional wire. Also made a wire from engine valve cover to the shock strut mount bolt nearby. These all doesn't help. How you did a ground in your car ? ---- Could bad battery be a reason of this new issue? engine runs roughly (or misfires) and stalls in the morning on cold. The second start always is good. I have new fuel pump GM MU1959 maybe this is the cause ? But according to the scanner, short-term and long-term corrections are normal
09-07-2023, 05:27 AM | #11 | |
09-07-2023, 09:07 AM | #12 | |
https://www.youtube.com/watch?app=desktop&v=pbSCICsau0M
the bald eagle machine is the guy offering the cables.
09-07-2023, 03:41 PM | #13 |
Drives: 2010 2SS RS Join Date: Apr 2023
Go to your local welding supply store. They will make you cables. Had 2 #1 Copper cables with copper ends done and paid $18.51 tax included.
09-07-2023, 11:40 PM | #14 | |
I just can't understand the relation of the hot oil to the bad cranking (or no crank)... Does hot engine require more battery power and more ground ?
