05-08-2012, 06:01 PM | #1 |
transmission replaced again !
okay so the dealer had my car for 11 days and put a whole transmission in again. before I had them work on the car I stated that when you have that clutch out and the car idleing in neutral you hear something rattling around in the transmission . after they replace the transmission I got your car back and it still makes the same noise . I'm on my third transmission how many more times until this car is considered a lemon. this transmission has other issues than this noise that's why they replace the transmission . now it only has that rattling noise when the clutch is released . I personally think it is the dual mass flywheel . the dealer says that the flywheel and clutch is not covered under warranty . is this true ? does somebody make a clutch kit that eliminates the dual mass flywheel ? also if I install the clutch myself will I void any other warranties ? the dealer told me that the transmission in my car is now on national back order .so it seems that general motors has realize there is a poroblem with the transmissions ! My car is a v6 m6.
05-08-2012, 06:06 PM | #2 |
[QUOTE= the dealer says that the flywheel and clutch is not covered under warranty . is this true ?[/QUOTE]
..what?!? find another dealer |
05-08-2012, 06:20 PM | #3 |
cruznls
CALL GM ..........
05-08-2012, 06:30 PM | #4 |
Lemon
.... Clutch is not under warranty..but this is not because the xlutch is burned out.. Sent from my SCH-I510 using Tapatalk 2
top 10 reason why real men drive stick. 10. A manual transmission is the ultimate in control 9. You can use automotive jargon and not sound like a total tool 8. You can't spell "manual" without "man" 7. Manual transmissions prove you can do more than one thing at a time 6. You can't drift in an auto 5. You can't pull fancy moves in an automatic 4. You get better fuel economy with a stick 3. You’ll never look like a chump if you can drive stick 2. Manual transmission cars are faster 1. Women like a guy who is good with his hands. |
05-08-2012, 07:49 PM | #5 |
the clutch is not burnt. it sounds like the springs in the dual mass flywheel are bad . it chatters real bad at idle .
05-08-2012, 07:59 PM | #6 |
Drives: cars Join Date: May 2011
Clutches depends on mileage if they'll be covered. It's a wear item like brakes. Dealer sounds like an idiot though if they keep replacing the same part and expecting a different result. That's the definition for insanity.
05-08-2012, 08:03 PM | #7 | |
