03-27-2013, 10:29 AM | #1 |
Rear light bezels
Anyone know how I can get my rear light bezels black? I have a black Camaro and I am wanting to black it out.
03-27-2013, 10:46 AM | #2 |
Drives: 2011 CGM Camaro LS A6 Join Date: Jan 2011
Spray paint them or plasti dip
03-27-2013, 10:46 AM | #3 | |
Drives: 1965 Chevelle Malibu Join Date: Jan 2012
Option #1: Plastidip them. About $11 per can. Not permanent so you can always remove it and go back to stock if you like. Option #2: Black vinyl. Order some of the 3M 1080 automotive vinyl, and spend some time heating and forming it to your bezels. You can also always peel the 1080 off if you want to go back to stock. You can also use 3M DINOC, which has a more permanent adhesive and from what I understand will mold a little better because of the strength of the adhesive. Removing it will be much more difficult. Note: unless you know what you are doing, wrapping them can become a pain and you may end up with the wrap lifting in certain places. If you use 1080, you may want to pick up a can of 3M adhesive promoter and lay that down first. That is also easy to remove should you decide to go back to stock. Option #3: Paint them. I have done all three of these options. Just recently took the 1080 carbon fiber wrap off of them and painted them Satin Black. If you are going to paint them, you will want to grab some fine grit sand paper, or scotch brite and rough up the surfaces a little bit. You can prime them if you want, but it is not absolutely necessary and you probably won't notice any difference. I used Satin Black Rustoleum and couldn't be happier with the results. Go over them several times. Don't try to get them in one heavy coat or you will likely get runs in the paint. I went over mine about 5 or 6 times until I was satisfied. Note: if you paint them, also make sure you tape off your tabs before you start painting. This is all my experience. Other people here may have different experiences/opinions. All 3 of these worked fine for me, but I am happiest with the look I got from painting them. I hope this is helpful. Good luck.
03-27-2013, 12:47 PM | #4 |
Drives: 2018 Hyper Blue 1SS 1LE Join Date: Jul 2011
I plasti-dipped mine
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic Car Build: http://www.camaro6.com/forums/showth...0#post10049680 |
03-27-2013, 01:50 PM | #5 |
YUDLOSE
Drives: Supercharged 2010 ABM 1SS Join Date: Aug 2011
You can buy a set of matte black bezels on ebay for around $70.
Trey Jenkins 2010 Supercharged ABM SS Camaro LS3 #400 Order Number: NJGC85 Build Date: 06/24/2009 1996 Blue Z/28 Camaro 396 stroker in the process 1994 Red Z/28 Camaro |
03-27-2013, 04:15 PM | #6 |
Drives: 2013 Camaro 2SS RS Join Date: Jan 2013
I bought mine from Lupe @ overhaulengines. From the pictures and praise on here he does excellent work and the price is very reasonable. Plastidip is nice, but isnt long term.
03-27-2013, 05:57 PM | #7 |
Drives: 2010 1SS/RS Inferno Orange Join Date: Jun 2009
Get a can of SEM trim black. It matches all factory matte finishes. Like $5 a can, scuff them up really good with a sotchbrite pad. Mines still perfect 2 years later.
03-27-2013, 06:10 PM | #8 |
Drives: 2012 1LS Camaro (Victory Red) Join Date: Sep 2012
Plastidip them! No scuffing needed and you can always peel it ofd if you screw up or eventually want a change. Once it gets warm thats what i will be doing and use the $60 extra on something else
03-27-2013, 08:36 PM | #9 |
YOU.ONLY.LIVE.ONCE
Drives: Camaro 2LT/RS 2013 Join Date: Aug 2012
I plastic dip mine but looks cheap and attracts more dirt. I took it off and went back to chrome. After seeing the bezel from 45th camaro I am obssess about it and ordered it from Maureen kinda expensive but its not just a car its camaro. I would say if u like black go painted or go home. Kidding!
03-27-2013, 08:40 PM | #10 |
Plasti dip looks cheap, paint them
03-27-2013, 08:51 PM | #11 |
YOU.ONLY.LIVE.ONCE
03-27-2013, 09:05 PM | #12 | |
Drives: 2010 IOM Camaro Join Date: Aug 2012
I will second Lupe work. He did mine..Plasti dip is not long term, but I guess would work. Mine are not plasti dip but are painted flat and not as Glossy as pic above |
03-27-2013, 09:08 PM | #13 |
Drives: 2012 SS Join Date: Mar 2013
03-27-2013, 09:18 PM | #14 |
could do a satin
