10-21-2015, 10:56 AM | #1 |
Drives: 2015 1LE Join Date: May 2015
Some interesting results from the GEN 5 fuel system
This summer I've been testing how far our fuel system on the Gen5 can be pushed and I'm pretty impressed.
Since my car is a 15 1LE it came with the ZL1 pump-so with a set of 90lbs injectors and single nozzle meth kit and supplied ECS BAP I was easily able to make 740 rwhp-but the real test was on the street and track-that's where the real load is. So a week after I installed the ECS kit I took the car to Smith Falls and ran 150mph in 2310 feet, 330 feet less than the half mile. My duty cycle was 78% at 7000 rpm and pump pressure dropped from a commanded 58 to 48 psi. So even thought the pressure dropped the system still was able to maintain the AFR commanded and still be safe. So of course I wanted more so I opted for the 3.45 pulley which led to a power jump of 814 rwhp. With the same fuel system the duty cycle jumped to 88%. Fuel pressure dropped from 58 to 46-still the system was able to maintain the AFR I commanded. It was safe but the headroom just got smaller. Now I wanted to try the FPCM's that come with the ZL1's-these allow us to increase pressure over 58 psi. Unfortunately you can't just pull one from a ZL1 and pop it in since it the ZL1 uses a E67 pcm-swapping pcm's was an option but ADM makes a modded FPCM to work with the E38-easy breezy. Voila-the fuel pressure commanded now is 65psi and the system is delivering 63 psi at 7000 rpm. Duty cycle is now only 66% at 7000 rpm-and the AFR is where I'm commanding it. So basically out of a stock system and 90lb injectors we are over 800 rwhp with room to go even further yet. So for the cars that don't have the ZL1 pump-swapping is a simple upgrade and pumps can be had for around $300. The ADM FPCM can be had around $225-add an injector and 800rwhp can be done pretty simple without killing the bank. And if you wanted to keep it even simpler-you could just add the FPCM to get more out of the stock pump. Guys always ask me what injector and the simple answer is the biggest you can afford-the Bosch 90's we use are only $570 US and there plug and play-no adapters to connect or fail-and after tuning they drive perfect. So if you have a ZL1-just skip the popular 60's and go straight to the 90's. One and done. I'm pretty impressed with this fuel system-no return line and 800 rwhp is pretty impressive. GM really did a good job with the pump and FPCM setup. So if your making fuel system decision this offseason-this bit of info may help. |
10-21-2015, 11:03 AM | #2 |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
Very nice, thanks for sharing. Did you leave the Boost a pump in or remove it when you added the ADM fpcm?
10-21-2015, 11:07 AM | #3 |
10-21-2015, 12:46 PM | #4 |
Drives: 2018 Charger SRT 392 F8 Green Join Date: Aug 2010
So what's the limit with the stock SS pump? Not the ZL1 pump.
10-21-2015, 12:57 PM | #5 |
I have a car here making 700 rwhp with the stock pump and dual meth nozzles. Duty cycle was 78%. if it had a FPCM-it easily make more-bigger injectors-even more-this car only had the Deka 60's as well.
The only negative I have heard is that the 10 pumps don't like the higher pressures for too long. |
10-21-2015, 01:17 PM | #6 |
Blue Streak
Drives: 2010 SIM 2SS Join Date: Dec 2012
I totally agree on the injector size. I went straight to id850's and did a ZL1 pump & ADM FPCM. When I added them, I went to a 3.4 pulley for my SLP blower. Since then I added a cam, meth, and 3.0 pulley. When tuning time came, I didn't have to worry about fuel. I nailed 676 whp & 611 wtq!
Now I need tires lol
2010 CAMARO 2SS SLP TVS2300 3.4 pulley, 9PSI Custom Tune, ZL1 FP, ADM FPCM, ID 850's, tr7ix plugs, CAI intake, KOOKS 1 7/8 & HFC, Magnaflow Comp catback, Pedders Xa coilovers & sway bars & sub frame bushings Mpd1 Z hood & spoiler, Vertical doors, Hurst short shifter, R1 dimpled/slotted rotors, SS brake lines, Hawk HPS Pads, Niche Apex & Nitto Invo front:20X10-275, rear:20X10.5-315, GM GFX & Satin gas cap, RS projectors, T3 bumper ports, T4 splitter, Alpine INE-W927HD, Metro dash kit
10-21-2015, 07:36 PM | #7 |
Drives: 67RS Camaro ,Black 2013 ZL1 Join Date: Jun 2010
The numbers are a little skewed when you add meth to the formula.
10-21-2015, 07:49 PM | #8 |
Lets roll...
Drives: 14' Join Date: Jun 2014
Thanks for sharing Vortech,
In your opinion, what would be the route you would go when going e85 conversion on a 2014 1LE (LTs, cai, ported TB). Would the FPCM be able to pull this off on stock injectors safely? If not, what injectors would you recomend?
10-21-2015, 08:06 PM | #9 | |
But I do have some data without meth which should help. 730 rwhp-no meth, bap, 90lb inj-duty cycle is 88%, IAT was 133 degrees at the end of a dyno pull. So meth was basically worth a 10% drop as indicated by my first post. I actually I did not want to use meth but the IAT temps concerned me and meth was the only answer to cure that other than building whole new intercooler. I didn't want to chance the hi IAT's at a runway event with a stock motor and pump gas so meth was my solution. I've been using it for 10 years now on my last 8 second C5 to this car and when setup correctly has never let me down. |
10-21-2015, 08:11 PM | #10 | |
Just like I stated earlier-run the biggest injector you can tune in properly-especially if your going to use E85, and there are plenty of 1500-2000cc injectors out there now. I know F1C has a good 1500cc injector that would probably be perfect for a stock pump since they don't like hi pressures. The bigger the injector the easier it will be on your pump. |
10-21-2015, 08:15 PM | #11 |
Lets roll...
So Im guessing you wouldnt chance it on stock injectors with only the mods I listed (LTs, cai, ported TB) on a 1LE car? Would stay well below 500rwhp.
10-21-2015, 08:26 PM | #12 | |
410 rwhp-68% 470 rwhp-78% Hope this helps. |
