12-04-2017, 06:16 AM | #1 |
WORK HARD PLAY HARDER
Drives: 2010 Red 2SS/RS Join Date: Apr 2012
Rear deck speaker harness help
2010 2ss/rs with BA system. Been searching the forums here for rear deck speaker adapter wiring harness. Don't want to cut the factory wiring harness. I have new 6x9's and speaker mount brackets. Don't want to start the install until I have everything I need. Thanks in advance.
12-04-2017, 12:14 PM | #2 |
Drives: 2013 ZL1 Join Date: Jun 2013
Look up fark wire harness in Google
12-04-2017, 03:39 PM | #3 |
I'm keeping the stock amp, just changing the 6x9's. Does the FARK(factory amp replacement kit) come with these adapters?
12-04-2017, 05:11 PM | #4 |
Basically I have to order a complete FARK kit to get the adapters that only give me just high or low signals to speakers. Or I can spend more money to replace the amp(which I don't want to do anyways) and get all the signals I want out of the adapters to the rear speakers? Is there not a way to utilize the factory amp and aftermarket 6x9's? Don't want to fry the amp by giving the 6x9's two signals. Is there no kit that will allow this? If not I will most likely cut up the factory speakers and make adapters(solder new wires on) to run just the low signal side of the amp. I have highs in the fronts anyways, just not my first choice.
12-04-2017, 07:18 PM | #5 |
Drives: 2014 Camaro 2SS/RS 1LE Join Date: Nov 2016
To do it right you will need a set of component speakers. I went with the Infinity 6030cs set and made an adapter to sit on top of the factory 6x9 spacer. There is 4 wires per speaker, 2 for the high and 2 for the low. Also you will need 2 ohm speakers or it will sound muddy.
You will have fun removing the rear seat and all the plastic to get to the rear speakers. There is a video on youtube on how to do it.
Mods: K&N CAI, AR long tube headers, high flow cats, NPP exhaust
12-05-2017, 08:00 AM | #6 |
I have kicker dsc6930. I think I figured out how to run them. Going to modify the old speakers and the new ones to work. I'll show how I did it after
07-12-2018, 07:56 AM | #7 |
Drives: 2013 Camaro 2LT RS Join Date: Jul 2018
Need hints
07-25-2018, 11:16 AM | #8 |
H-Town Camaro Club
Drives: 2013 Dusk Edition 2SS/M6/Sun/NPP Join Date: May 2014
