01-25-2010, 01:40 PM | #1 |
Drives: 2010 2LT RS Camaro Join Date: Oct 2009
Camaro tires
How much does one tire cost? I have the RS package so they are 20s. I found a nail in one of them this morning when the car told me the tire pressure was low...:(
2010 2LT RS Black Camaro with white stripes |
01-25-2010, 01:41 PM | #2 |
Drives: My wife crazy with my C5 usage. Join Date: Apr 2009
Which tire? Front and rear are different sizes. As long as the nail isn't in the sidewall, it should be patchable. I had a nail, pulled it and the rubber resealed not requireing a patch.
01-25-2010, 01:43 PM | #3 |
Drives: 2010 RY 2SS with Custom Stripes Join Date: Mar 2009
Bring it and get a $10.00 patch put on from the inside unless it is in the sidewall.
01-25-2010, 01:45 PM | #4 |
So Cal Race Team
this happened to me. took it to a tire place, they took off the tire, patched it from the inside, and re-mounted the tire, and balanced it for $25.
Don't have them put a plug in it. |
01-25-2010, 01:46 PM | #5 | |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
Yeah, just patch it. If for some reason (cut in the tire or sidewall damage) the tire can't be repaired, here's a link to Tire rack. You can get the front tires for $303 and the rear tires for around $350 http://www.tirerack.com/tires/TireSe...&filterType=oe |
01-25-2010, 01:51 PM | #6 |
thanks guys..the nail is not on the sidewall so hopefully I can just patch it up
01-25-2010, 02:00 PM | #7 |
Drives: 2016 Camaro 1LT RS Join Date: May 2009
Just get it patched as long as it is not in the side wall. The new plugs are great they look like a nail with a head on it. So the tire pressure helps keep them in place.
01-25-2010, 02:09 PM | #8 |
Drives: 2010 Camaro 1SS 2007 HD FLSTC Join Date: Aug 2009
01-25-2010, 02:10 PM | #9 |
Similar Threads | ||||
Camaro Laws | ChevyNut | Off-topic Discussions | 107 | 11-09-2016 05:40 PM |
Does the v6 have enough power? | cstproductions | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 305 | 08-29-2012 09:27 PM |
Setting up an IRS/Drivetrain for Drag Racing | Kyle2k | Suspension / Brakes / Chassis | 44 | 06-05-2010 09:17 PM |
GM memo to dealers | Moose | 5th Gen Camaro SS LS LT General Discussions | 41 | 02-04-2010 07:33 PM |
