06-26-2020, 05:55 PM | #1 |
Drives: 02 Camaro B4C Join Date: Nov 2016
Vents blowing HOT air.
So first off the A/C seems to work fine. However when the AC is off even with the temp control fully cold the air coming out the vents is hot. So even on mild days when I want to drive with the windows open the air coming out the vents is hot.
Any suggestions would be appreciated. Thanks Craig
A man's garage is his castle
1969 Camaro SS 1970 Camaro SS 2002 Camaro B4C 2014 Camaro SS Dedicated Track Car 2015 Camaro 1SS 1LE 2008 HHR SS 1996 Silverado Crew Cab Long Bed Dual Rear Wheel |
06-26-2020, 06:29 PM | #2 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Umm, blend door?
06-26-2020, 07:16 PM | #3 |
that's what I'm wondering but my symptoms seam a bit different than what I have seen on the site.
06-26-2020, 07:28 PM | #4 |
Drives: 2015 2SS A6 Commemorative Edition Join Date: Nov 2019
This is the same thing that my Camaro does. A/C blows cold, but if I turn it off the air seeping out of the vents feels 10-15 degrees warmer than the outside air.
06-26-2020, 07:57 PM | #5 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Its calked vent. Every car I have had will blow warm air if you turn off the a/c but keep it on vent.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
06-26-2020, 08:16 PM | #6 | |
Drives: 2011 Camaro SS Join Date: Dec 2016
06-26-2020, 08:59 PM | #7 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
Mine does the same thing.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
06-27-2020, 06:59 AM | #8 |
Found a link for ya. Basically its normal. If memory serves I want to say GM has always kept the blower motor running even if the system is off so there is constant air flow through the cabin of the car. My '79 was like this also. I think I was told its so fumes cant just build up or something. Granted we are talking about a memory from over 20 years ago so take that part with a grain of salt.
https://www.quora.com/Why-does-my-ca...-the-AC-is-off
2013 Camaro SS/RS, Stainless Power long tube headers with HF's, Air Raid CAI, Solo Mach XL cat back, BC Racing coil overs, Elite Engineering catch can, Ferrada Forge 8 Wheels, Windows tinted at 20%, Tuned by Dyno Steve.
06-27-2020, 08:14 AM | #9 |
thanks for the responses. it just seem odd to me that the "vent" air is 15*-20* hotter than the outside air. It forces you to run the A/C when you shouldn't need to.
thanks Craig
06-27-2020, 11:14 AM | #10 |
Drives: 2010 Camaro 1LS 3.6 LLT V6 325 HP Join Date: May 2009
Very common, its called heat soak, especially when you park in the sun.
The vents, ductwork, and blower all warm up which heats the incoming air. You should have no problem on a 60 deg day running the vent. Summer time is a different story.
06-27-2020, 12:52 PM | #11 |
Banned
Drives: 2015 Camaro Join Date: Aug 2018
Once you get into the 70's ambient air, the vent will start to feel a little warm. Completely normal.
06-28-2020, 12:29 PM | #12 |
Obsessed
Drives: 2016 Hyper Blue 2SS RS Join Date: Jun 2011
Mine did that, much hotter then the outside air... that is what was really weird, felt like the heat was on, it was the blend door.
$700 to fix it, had a repair place cut the door out from under the dash and replace it. Dealer will need to pull windshield, pull dash, and replace. $1500-2000. If you are handy you can do yourself. There are YouTube videos. Check some of these: https://www.camaro5.com/forums/showthread.php?t=528157 I hope it's not your blend door, but think it is. Best wishes, Jim
2016 Hyper Blue 2SS |
