04-16-2012, 07:51 AM | #15 |
Drives: 2010 Camaro IOM 1SS M6 Join Date: Aug 2010
If it was my $30,000 plus car without question i would at least take it in and have the dealership take a look at it and see if your warranty will be honored, no harm in asking
04-16-2012, 10:23 AM | #16 | |
Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
This is a pretty common observation with the Corvette. Most times the dealer adds a bottle of the GM additive and the noise subsides. In some cases if the noise is awful it may need extra service, but for the most part the LSD additive takes care of the noise. I would definitely take the car to the dealer, even if you have a modified engine. They should take care of the issue, and even if they don't the worst they can say is no. Either way you haven't really lost anything. |
04-16-2012, 10:48 AM | #17 |
Drives: Green Dream Machine Join Date: Mar 2011
Mine almost sounds like an electric motor winding up, could this be that same sound?
04-16-2012, 10:54 AM | #18 |
Drives: 2011 Black RS/SS Join Date: Feb 2012
Great, I just had my harmonic balancer replaced and now my '11 is making this noise too.
04-16-2012, 06:34 PM | #19 |
When mine started making this noise last August, I bought the car in May, I had her in 3 times between August and December for a fluid and additive change, but the noise kept coming back, so the last time which was the end of December my mech decided to rebuild the diff, since then,Jan 5th, all has been great. I drive the car like it is supposed to be driven, hard and have been to the track twice for 6 runs down the 1320, so far, so good. Good luck man..
04-17-2012, 07:23 AM | #20 | |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
My dealer put a bottle in for me, free of charge. Haven't heard it since. Like Pfadt said, it's a common issue on the vettes and apparently ours are prone to it as well.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
04-19-2012, 12:50 PM | #21 |
Drives: 96 Z28 SS, 2010 SS RS Join Date: Aug 2009
Mine did that, but after I put the RP in it. After 100 miles, I drained it, put the GM fluid back in with the 4oz of friction modifier (you need this) and havent had any issues since
"Start brain before placing mouth in gear".
04-19-2012, 12:56 PM | #22 | |
Why would you drain the RP out and replace it again with the GM fluid? I am considering replacing both the transmission and rear diff with RP so I am just curious why you would go back. Thanks |
Similar Threads | ||||
HUGE Sale. Proven Wicked ProRIGID End Links up to 30% off! | Proven Wicked | Suspension / Chassis / Brakes | 31 | 06-01-2012 12:10 PM |
CEL - P1682 | PSU SS | Tuning / Diagnostics -- engine and transmission | 4 | 09-29-2011 07:27 PM |
Setting up an IRS/Drivetrain for Drag Racing | Kyle2k | Suspension / Brakes / Chassis | 44 | 06-05-2010 09:17 PM |
Drag Racing Suspension Kits | Info@PeddersUSA.com | Suspension / Chassis / Brakes | 25 | 02-21-2010 08:48 PM |
Suspension guys out there - lets talk wheel hop | Crowley | Suspension / Brakes / Chassis | 14 | 10-09-2009 12:06 AM |
