Old 07-27-2021, 11:23 AM   #1
linc400
linc400's Avatar
Drives: 2012 2LT 45th anniversary convert
Open latch message
When I unlatch the top, and press the button to lower the top, I get a message on the dash that says "unlatch top" even though it is already unlatched. The dealership says it needs a whole new latch mechanism which is $459 installed. This seems high. Does the whole mechanism need to be replaced, or is there some less expensive way to fix this?
linc400 is offline   Reply With Quote
Old 07-27-2021, 05:55 PM   #2
Mike J
Mike J's Avatar
Drives: 2015 Topless Btch RS
Have a look a this
Mike J is offline   Reply With Quote
Old 07-27-2021, 06:34 PM   #3
linc400
linc400's Avatar
Thanks for the info, but this seems to be the opposite of what I have. This is saying "top not secure" when the top is up. My top won't go down.
Old 07-27-2021, 06:55 PM   #4
futureZ
futureZ's Avatar
Drives: 11 camaro 2lt rs
Clean out the micro switch area maybe? Maybe some debris preventing movement?
futureZ is offline   Reply With Quote
Old 07-28-2021, 05:27 PM   #5
linc400
linc400's Avatar
Thanks. I will see if anything can be done with that. But the top won't go down, so I don't think I can get in there.
Old 09-06-2021, 11:32 AM   #6
Cristjw
Cristjw's Avatar
Drives: 2014 Camaro RS 2LT convertible
Can we manually lower or raise (gulp!) the tops?
Cristjw is offline   Reply With Quote
Old 09-06-2021, 04:00 PM   #7
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
Yea you can manually open the top. The car should of came with the tool to do so. There is a spot between the seat for the tool.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
