03-15-2019, 12:40 PM | #1 |
Drives: 45th Anniversary Join Date: Nov 2015
Header Install
Hi All, Anyone on here from the Orlando FL area that knows of a good exhaust shop to install Kooks LTH's? Thanks in advance.
03-15-2019, 01:42 PM | #2 |
Started#gottalovethatblue
If you have a jack and some stands, do it in your garage. The installation really isn't too hard and you'll save yourself $400 on an install. Not to mention, you have the bragging rights of having done it yourself.
03-15-2019, 01:54 PM | #3 |
Drives: 2010 SS L99 Join Date: Sep 2018
Pyro FTW again. DIY, its too easy. Think of what else you could do with that extra $400... trailing arms and toe rods, or cradle bushings, or a BMR sway bar...or a cold air from CAI...all kinds of neat stuff!
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
03-15-2019, 06:04 PM | #4 |
USA-1
I third that...while it's not the most enjoyable install, there really isn't anything 'hard' about it.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
03-16-2019, 11:10 AM | #5 |
Space Shuttle Aficionado
Did it in my cramped garage in 15 degree weather (The heater wasn't doing much that day). The install was straight forward.
03-16-2019, 11:28 AM | #6 |
Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
I've done 4 installations in my garage.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
03-16-2019, 01:07 PM | #7 |
Drives: Blaze Red 2014 2SS/RS Join Date: Sep 2016
at the age of 62 I installed my own by myself...
03-17-2019, 09:20 AM | #8 |
Drives: 2010 RJT 2SS M6 Camaro Join Date: Feb 2011
Easiest car to install headers on.....ever!
2010 RJT 2SS M6, Kooks Long Tubes, NPP Exhaust, CAI Cold Air w/Jannetty Scoop, RotoFab Washer Bottle, Elite Engineering Catch Can, MGW Shifter w/ZL1 Shaft and Knob, 2015 SS Sedan Steering Wheel and Air Bag, 2012 Heater Hose Conversion, 2012 Power Seat Conversion, RS Head Lights,Gen5DIY RS Conversion Harness, LED Fog Lamp Bulbs, Backup Camera Kit, NLP Spoiler, SLP Splitter, ZL1 Rockers and Diffuser, Color Matched Shark Fin, RS Roof Mouldings, Painted White Stripes, WCC LS3 Emblems, Heritage Grille and Blacked Out Tail Light Panel w/Retro SS Emblems, 416 RWHP, 411 RWT, Tuned by BlueCat.
03-17-2019, 10:30 AM | #9 |
Drives: 2011 1SS/RS IBM Camaro Join Date: Jan 2011
i know all you guys are right no argument from me. But no one directly answered his question.
03-17-2019, 10:46 AM | #10 |
Any exhaust should be able to install them.
03-17-2019, 02:45 PM | #11 |
I agree with Ralph, any exhaust shop should be able to install them. It'll cost $400+ but any of them should be able to install them. $400 could buy a guy a nice jack, stands, pizza, and beer for his buddy to help with the install. Just remember, keep a mental not where the dip stick fit in, spray PB Blaster on the O2 sensors the night before and when you get ready to uninstall the old manifolds the next day so they don't tear any threads, torque the bolts from the middle out alternating sides as you tighten, and 10ft/lbs torque first then 18ft/lbs, heat cycle and retighten at 18 once again.
03-17-2019, 03:12 PM | #12 |
Drives: 2015 1SS Join Date: Jan 2019
03-17-2019, 03:15 PM | #13 |
USA-1
Sure! Power tools!
03-17-2019, 04:05 PM | #14 |
Get the front end up as high as you can so you can slide the headers in, and then really watch out for the spark plugs..pretty straightforward install too
