10-17-2020, 04:33 PM | #1 |
Drives: 2010 Chevrolet Camaro V6 Join Date: May 2017
Leaking orange! Any ideas what it could be please?
Hi all,
I've noticed today that I've got some leaking orange fluid on the floor under my Camaro (2010 V6). Looks to be a couple of droplets. Any thoughts on what/where this could be please - and to what level does my worry-meter need to be at? Thanks! Paul. http://motorcloud.net/wp-content/upl...20/10/leak.jpg |
10-17-2020, 05:08 PM | #2 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
Orange is (usually) coolant.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
10-17-2020, 05:16 PM | #3 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
This. Dexcool is orange.
Sent from my Pixel XL using Tapatalk
10-17-2020, 07:25 PM | #4 |
Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
that's what mine did right before head gasket blew
Hot Wheels Emblems and Floor Mats, Morimoto Fog Lights, PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting & My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller & Paddle Shifter Heritage Grill, Manual Shifter Boot, CNC Throttle Body, Trifecta Tune, Trunk Black out and Side Grills, Hot Wheels door Sills.
10-17-2020, 07:38 PM | #5 |
The Chevy place said my thermostat was going bad. So we replace the thermostat Housing and Thermostat along with some hoses ($900). then 3 Months later the Drivers side head gasket let go($7000). Mine you i was doing everything i could do to save the timing chains Regular oil changes Maintenance on Coolant.
When I got a new engine, I Got it with a 3YR/30,000 warranty in writing, and that included everything they had to take off the car. These engines are just not good for a 100,000 miles in the 2010 - 2012 Camaro's I'm sorry, but they are just not good engines, I just love the way the car feels.
10-18-2020, 03:28 AM | #6 |
Thanks everyone. Sounds potentially terminal then.
I'll get it checked out by a specialist next I think before I drive it any more just to be on the safe side. Lets hope its just a leaky pipe! |
10-18-2020, 12:52 PM | #7 |
Drives: 2011 Camaro 2LT/RS Join Date: May 2015
common leak on 3.6 is coolant inlet housing seals.
