04-13-2020, 02:23 PM | #1 |
Sun roof loose
Hey there my Camaro friends!
I was driving with my sunroof closed, sunroof shade open, and windows open, when I hit 55mph the wind buffeting made my closed sunroof start flapping up and down, scared me pretty good. I checked the 6 screws that can be accessed from inside the car, all were tight. Awhile back I started to notice it was rattling louder and louder when it was fully open. I can push on it with low-medium effort when closed and it moves up about 1/4-1/2 inch. Any ideas what could be the problem?
SOLD: 2010 2SS/RS L99-A6 K&N CAI, Speed Engineering Long Tube Headers, Stainless Works hi-flow cats, Flowmaster American Thunder Cat-back. Tuned by Corvettes of Westchester. 1/LE rear suspension conversion, Bilstein B6 Stuts/shocks.
04-13-2020, 04:46 PM | #2 |
Drives: 2014 Camaro SS L99 Join Date: Dec 2016
You could have a broken track if all of the screws are tighten down properly. Have you tried moving it at all without loosening any of the screws? Does it move?
Sent from my HD1925 using Tapatalk |
04-13-2020, 05:24 PM | #3 | |
Thanks for your reply Rob, I did check it without loosening the screws, it moves up and down. I never loosened the screws, I just checked to see if they were tight. How could the track have broken? I do use it a lot I guess, but nothing ever hit it.
04-13-2020, 05:36 PM | #4 | |
04-13-2020, 06:07 PM | #5 | |
Rob, Thank you so much for that information. Is there a way to inspect the track and look for where it is broken? 1-2 hour job seems decent. I would try and tackle it myself.
04-13-2020, 06:18 PM | #6 | |
04-13-2020, 06:19 PM | #7 |
Also while you're taking apart the interior, clean your drain holes for the sunroof or you'll experience water build up pouring inside
04-13-2020, 06:46 PM | #8 |
Thank you for all of your help Rob!
04-13-2020, 06:53 PM | #9 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
Mine does the same thing. The track wasn’t broken on mine. I would be interested to see if yours is.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
04-13-2020, 07:26 PM | #10 | |
I will be sure to post up in this thread after I inspect it. Should get to it later this week.
04-17-2020, 01:07 PM | #11 |
I looked at my sunroof. I didn't take headliner down as I did not see a need to. It is loose on one side, but I can't tell what is loose. If the track is broken I can't tell, as there is no visible cracks.
04-17-2020, 03:36 PM | #12 | |
04-17-2020, 07:40 PM | #13 | |
The glass and the frame look fine, the tracks look fine. When I shake it, its wiggling from where the sliders sit in the track.
04-17-2020, 09:36 PM | #14 |
It's gotta be the track or another mechanism right there with it. If you look for the parts on gmpartsdirect under the sunroof it's parts 2 &9 I believe are what you would be looking for
