04-23-2017, 07:48 PM | #1 |
Drives: 14 Camaro SS LS3/M6 Join Date: Jul 2016
Broken Chin Splitter
My ACS splitter was improperly installed by yours truly and only lasted two days. Lost a few chunks on the highway. Is there anything I can do i.e. putty, sand, paint or cut to get this looking any better. I bought it on eBay for $200, so not a huge loss, but if it can be fixed I'll try that first. Thanks.
2014 LS3/M6, SS4NFC, GPI Heads, Ported Rod/Mod Intake, LTH, PTB, UDP, CAI, 3.91, LSA Injectors and Fuel Pump, E85, Tuned by GPI 532rwhp/473ft-lbs tq. 11.37 1/4 Mile @ 124 MPH, Member of the SBE Killaz, Founder of the River Valley Camaro Club. IG @ARCamaro5
04-23-2017, 08:14 PM | #2 |
Drives: Miss Con Ception Join Date: Aug 2016
Duct tape fixes everything.
2011 1SS/RS LS3 CGM
04-23-2017, 08:50 PM | #3 |
Drives: 2013 Camaro Dusk 2SS/6 Join Date: Sep 2013
what is it made out of?? I seen some plastic get repaired using a soldering iron... sorta melt it back together. then you could use epoxy and fiberglass tape on the backside to help support (this is how they repair lots of urthane bumpers)... fill and repaint. but I'm guessing you missing the pieces.
could probably repair with fiberglass but that will be a PIA and time consuming. probably easier just getting another one. |
04-23-2017, 08:58 PM | #4 |
Drives: 2014 2SS/RS Join Date: Dec 2014
That is minor damage ...
Cracked and chipped the running boards on my Chevy conversion van many times over the years and used fiberglass and bondo to repair stronger than new - repairs turned out perfect. You could contact the manufacturer and ask them what method repair they recommend. Ron
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
04-23-2017, 10:15 PM | #5 |
DAP-ONE [COTW - 12/23/13]
I've had to order 3 ACS Splitters because of damage. Unfortunately, there isn't much you can do for those damages in your pics. You will have to order a replacement. Good luck!
04-24-2017, 01:28 PM | #6 | |
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
04-24-2017, 06:28 PM | #7 |
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
Yeah, the ACS will shatter. Lost part of mine coming out of a Chevron a few years back. I installed it right... but my car is lowered and even at an angle coming out of that carefully, still scraped, shattered... and well on to the next one. I went through 3 splitters total before I converted to the ZL1...
04-24-2017, 07:11 PM | #8 |
[COTW 4/13/15]
Drives: Supercharged LLT Join Date: Jul 2010
Not sure what ACS is sending nowadays, but when I installed my T5 in 2013, they sent splitter push rivets I believe they're called. I chose to get quality bolts to secure it versus the plastic rivets. No issues.
04-25-2017, 10:19 AM | #9 | |
The install kit that came with the T5 has 2 of the push pins. It came with Nuts and bolts .And after doing some reading around here I went and picked up some more nuts and bolts just in case . So it should be pretty solid .
04-25-2017, 06:24 PM | #10 |
I put in the two main bolts and the ten rear. It did well around town, but once I hit 90 on the Hwy air came in the front ripping it down. I will have the next professionally put on lol. Not sure what I did wrong.
04-25-2017, 06:28 PM | #11 |
That's how I destroyed this one... you live you learn...
04-26-2017, 09:31 AM | #12 |
The 10 bolts are suppose to be for the holes you drill . Did you drill the new holes and install the bolts in them? I'm guessing no.
04-26-2017, 06:59 PM | #13 |
Drives: 2014 2SS/RS Join Date: Jun 2013
Definitely repairable. It's made of fiberglass and I've had to repair mine before. To be honest, the hardest part was finding someone to paint it for a fair price.
Also with this same repaired splitter I've gone 180 mph. I guess make sure you have all the bolts where they're supposed to be |
04-29-2017, 07:14 PM | #14 | |
