08-25-2023, 07:01 PM | #1 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
Factory Driveshaft Bolts and Coupler part # help needed.
Hi, So I am not giving up on my 1 piece shaft but we all know parts are getting harder to find for these cars so I would like to put a couple parts on the shelf. Can you guys just confirm that I am correct with my numbers, 2014 SS LS3.
BOLT - Coupler to Trans Yoke 92138569 x 3 Nut - 92228333 or 90538867 x 3 Bolt - Coupler to Diff 92139104 x 3 Coupler - 5144110315, GAC02-004 ( Are these the same front and rear? ) I am not sure what the GM Part number is. Center bearing - 22810753 Shaft to Coupler bolt - 92228335 x 6 Coupler bolt washer - 92228334 x 6 Same nuts as above x 6? Thank you
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. Last edited by Joe.G; 08-25-2023 at 07:15 PM. |
09-07-2023, 09:55 AM | #2 |
Your diff couplers/FLEX DISC. will be discontinued. I went with a aftermarket brand
Actionmachineinc.com part# PTI GAC02-004 ... They matched perfectly
TSP 229/244 .629"/615" CAM w/ a bunch of goodies 465whp/443tq tuned by MayhemMotorsports-NC
09-07-2023, 09:58 AM | #3 |
I got these, they have all the same markings as Factory except the longer part #.
https://www.ebay.com/itm/35474807520...mis&media=COPY
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
09-07-2023, 02:33 PM | #4 |
as long as the numbers match on the coupler you should be ok (GAC02-004)
09-07-2023, 03:21 PM | #5 |
