10-22-2021, 06:04 PM | #1 |
CAR-DASHIAN
Drives: 2015 Ashen Gray Metallic 2SS/RS L99 Join Date: Nov 2015
Tim King Transmissions - Stage 3 6l80?
Anyone running one of these?
Looking for information on its manners, ie... shifting (full and part throttle), noises, ect. Any help is truly appreciated. Thank you
PERFORMANCE: ColdAirInductions CAI, ADM Race Scoop, Cordes Performance Racing Ported TB/IM/Custom VVT Cam, WFO Milled Heads, Stainless Power 1 7/8" LT/3" HFCs, JBA 3" Comp. Cat-Back, Taylor 10.4mm Plug Wires, Tim King Performance Stage 3 6L80, Circle D Billet 3600 Stall, Nic D ECM/TCM Tune, - 458rwhp/413rwtq (prior to PIM), Forgestar F14 (F)18" / (R)17" Rims.
SUSPENSION: Z/28 Rear UCA Bushings, Carlyle Racing LCA/TA, BMR Adj. Toe Rods/Xtreme Anti-Roll Bar, Justice Pete Castor Locks/Radius Rod Inserts, Pegasus Billet Rear Cradle Bushings, Mickey Thompson Street SS II 305/45/17 tires. |
10-28-2021, 11:26 AM | #2 |
CAR-DASHIAN
Nobody???
10-28-2021, 02:35 PM | #3 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
All I know that Tim King has a very good reputation on here, and everyone I remember having work performed by him had no issues.
10-30-2021, 11:57 PM | #4 |
Drives: 13 1LE 1SS/05 ZX10/02 Silverado/14 Join Date: Nov 2014
Did you get the trans? How’s it working out for you if you did?
02 Stepside Silverado
05 ZX-10 13 1LE 14 Nightrod Special |
11-02-2021, 04:24 PM | #5 |
CAR-DASHIAN
I got a Stage 3 but it had to be sent back. I have it back but I think it still shifts weird.
I have never ridden in a car with a built trans so I have no point of reference if it is working correct or still has a problem.
11-02-2021, 06:04 PM | #6 |
What is is doing? Or not doing that makes it feel weird??
11-02-2021, 07:18 PM | #7 |
CAR-DASHIAN
Part throttle upshifts (1-2 and 2-3) nose will dip, like something is binding. Full throttle 2-3 has a good size rpm flare and seems to take longer than it should. Once every 50-100 starts, when it fires up I get a higher pitched clunk that comes from what sounds like the center of the car.
Also has a noticeable clunk during the part throttle shifts, but that could be the ZL-1 diff or DSS driveshaft I put in at the same time. Haven't had the time to dig deeper into exactly where it is coming from.
07-13-2022, 08:37 PM | #8 |
Drives: Camaro SS/2SS Join Date: Jan 2017
updates?
