Old 09-22-2013, 02:32 PM   #1
PatS
PatS's Avatar
Drives: 2012 Camaro 2LT
cruise control adjuster
So when I am driving along HWY 50 here in Southern Colorado, there are a couple of places where the speed drops by 10 miles and hour. Unless I have to (slower traffic or a light) I don't usually use the brakes. I just use the little button to increase/decrease the speed. So if the speed drops from 65 to 55 then I will just notch the speed down by 10 MPH using the steering wheel control. Does anyone else do this and are there any drawbacks other than the control wearing out sooner?
PatS is offline   Reply With Quote
Old 09-22-2013, 03:05 PM   #2
06_warrior
06_warrior's Avatar
Drives: 2012 1SS LS3 M6 black on black :)
The only draw back would be if a cop was setting a speed trap and by adjusting the speed lower by the CC button it might not drop fast enough if you were adjusting it right at the lower speed limit sign. Other than that you can press the CC cancel button and when the speed lowers to the desired speed you just set it again.
06_warrior is offline   Reply With Quote
Old 09-22-2013, 07:00 PM   #3
RJT Impala
Stovebolt BluFlame 6
RJT Impala's Avatar
Drives: '12 2LT/RS, IBM; '20 Traverse Prem
I do the same thing OP does as I approach I vehicle, if I'm hemmed in by traffic and can't pass. Or I disengage the CC using the "cancel" button as mentioned above. Nice having everything on the steering wheel.
RJT Impala is offline   Reply With Quote
Old 09-22-2013, 07:23 PM   #4
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
I do the same thing.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
PalmerGA is offline   Reply With Quote
Old 09-22-2013, 07:36 PM   #5
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
I usually hold the set button in until it slows to within a couple MPH of the speed limit as soon as I see the sign or if there is a reduce speed ahead sign I do it then.
The Bird is the word!
Old 09-22-2013, 10:06 PM   #6
Oldag
Drives: 2013 2SS Convertible, LS3
Use it the same way. That is the button's purpose.
Oldag is offline   Reply With Quote
Old 09-22-2013, 10:14 PM   #7
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
Every time you mash the + or - button and release it equates to one mph....at 55...mash and release the + button 10 times...you'll be doing 65.... Vice versa... Mash and release the - button from 55 mph..10 times you'll be doing 45
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 09-22-2013, 10:25 PM   #8
revived
Vrrrm.
revived's Avatar
Drives: 2011 2SS/RS LS3
I wouldnt worry about it wearing out, it only takes a gental few taps to drop the set speed down.
revived is offline   Reply With Quote
Old 09-22-2013, 10:31 PM   #9
2012-1822
2012-1822's Avatar
Drives: Black ZL1
When I'm up on the highway and sitting comfortably, it's all steering wheel controls for radio and speed.
Check out Alabama Camaros, for Camaro enthusiasts all around Alabama https://www.facebook.com/groups/1739...group_activity
2012-1822 is offline   Reply With Quote
Old 09-22-2013, 11:19 PM   #10
OHIOSS
Russ
Drives: Yukon Denali, Charger, CamaroSS
Send a message via AIM to OHIOSS
I have done this since I've had my SS in June 2009. I use CC more than anyone else I have ever seen. I even use it in 25MPH zones so I am sure not to speed. Everything still works as new so doubt if you will wear anything out.
Russ
OHIOSS is offline   Reply With Quote
Old 09-23-2013, 10:33 AM   #11
ninety6
2xSOM
ninety6's Avatar
Drives: 2002 Camaro SS | 2002 Camaro V6 vrt
You should be able to hold the + or - down until you reach your desired speed, then release as well.
ninety6 is offline   Reply With Quote
Old 09-23-2013, 10:38 AM   #12
ravensjeff
100% Chevy & Harley Man
ravensjeff's Avatar
Drives: 2010 2SS: Blown LSX 376-B15
No problems; that is what it's for.
LSX 376-B15, TVS2300 SC, Harland Sharp Rockers w/ Trunion Bearings, ATI Balancer/keyed, AR LT Headers/Borla Catback Exhaust, DSS 1400 HP Axles, DSS aluminum driveshaft, 3.70, Hotchkis Springs/Sway bars, Forgeline SO3P Aluminum Wheels (20x9.5 F/20x11 R)w/ Hidden Titanium Hardware, Nitto NT05 Tires (27540ZR20 F/31535ZR20 R), Billet LPE brake/gas pedals, Escort 9500ci Radar Detector Laser Jammer, Roto Fab CAI with Ice Silver box, Carbon fiber tube/MAF Housing Assy, LPE Aluminum coil covers, SS9 Sleeper Fiber Glass Hood (ACS), Carbotech 1521 ceramic brake pads, Elite catch can.
ravensjeff is offline   Reply With Quote
