03-14-2019, 06:39 AM | #1 |
Drives: '14 BRM 1LE 2SS/RS Join Date: Nov 2017
Any of you RotoFab guys have this issue?
Just noticed yesterday that my hood appears to be raised a tad on the front right corner, most likely due to a clearance issue with my new RotoFab CAI (LSA version). I took it back out and verified that it was installed and seated correctly so I'm not sure what the issue is. I'm going to spend a little more time on it tonight but just wanted to see if anyone else had this problem.
592 HP/590 TQ
LSA Blower w/ 2.45 Griptec, Reinforced Brick, FIC 1000 injectors, JRE FPCM, LFP Dual Pass HX, ZL1 IC pump, RotoFab CAI, Bo White TB, Coated Stainless Power 1-7/8" LTs, NPP, NGK TR7IX, Mighty Mouse Wild CC, AEM X-Series WB, Aeroforce Interceptor, MGW Shifter, Z28 Grill, Gary's Custom ZL1 Rockers, Hero Tails, Tuned by IMC |
03-14-2019, 07:58 AM | #2 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
Is the stop holding it up or the gasket/seal? Mines not jacked.
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
03-14-2019, 08:12 AM | #3 |
Started#gottalovethatblue
When you say you have the LSA version, do you have the heat shield for a ZL1? That could be your issue. I think the underside of the hoods are a little different and the heat shield is formed differently because of it.
03-14-2019, 08:18 AM | #4 | |
+1 I'd look into shaving some off the bottom or trying to find a little extra clearance so it'll sit flush |
03-14-2019, 09:13 AM | #5 |
Drives: 2014 ZL1 Join Date: Aug 2015
I have found raising the stop on the opposite side from the intake helps because of the extra pressure from the intake seal.
2014 ZL1 Roto-Fab intake, 2" TSP headers, JRE 125 package and tune.
2015 2LT RS overkill tune, 80MM throttle body with JacFab spacer, ported intake manifold and Roto-Fab cold air intake. Vitesse throttle controller. |
03-14-2019, 10:29 AM | #6 |
Drives: 2014 SS 1LE Join Date: Apr 2014
My 14 1LE does the same thing and i dont have a rotofab CAI.
03-14-2019, 11:07 AM | #7 |
03-14-2019, 11:09 AM | #8 | |
Thanks for the tip, I'll check that out as well. |
03-14-2019, 12:30 PM | #9 |
RotoFab is one of the better fitting and made kits. Go back over your heat shield installation and make sure its where it needs to be.
03-14-2019, 12:38 PM | #10 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
Odd , my CAI fits perfect and there is plenty of clearance and it doe's not touch the hood at all .
OLD GUY FLYING FAST AND LOW
03-14-2019, 03:38 PM | #11 |
I have twin turbos so i dont even have a filter location there. Mine isnt as severe as OP's, but its similar just on the opposite side. Maybe its just me.
03-14-2019, 04:48 PM | #12 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
I have a GM CAI and it touches the under hood - cuz it’s supposed to! Lol
03-14-2019, 09:39 PM | #13 |
Yes as can be seen in your picture the passenger side is a little low now so if you raise it up some it should help with the drivers side also.
