06-04-2020, 08:46 AM | #1 |
Drives: 2014 camaro ss 1LE Join Date: Apr 2020
exhaust scrapping
I just bought a 2014 1LE and it has kooks long tubes and a full 3 inch kooks cat back system on it.
It seems so scrap alot more than what i feel it should. i see alot of companies like corsa, and borla saying that the 1le has the fitment of the zl1. I guess my question is, is there a way to get away from the scrapping sound whenever i hit those long swooping bumps on the highway? the Kooks system drones so damn bad i am going to remove it and was thinking about going with a corsa sport 2.5 inch cat back. hoping that will get ride of the drone and reduce the scrapping on the ground. |
06-04-2020, 09:47 AM | #2 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
First step is to figure out what part is scraping. It's likely the long tubes prior to the cat so a cat back system won't help.
06-04-2020, 07:33 PM | #3 |
Tri-County Camaro SWFL
Is the car lowered?
06-05-2020, 05:06 AM | #4 |
Drives: 2010 Chevy Camaro 2ss/rs TF edition Join Date: Feb 2019
My guess would be the collector clamps are hitting. Definitely get it on a hoist and take a look to make sure. As far as an exhaust with no drone, I highly recommend Solo Performance and their Mach X catback.
06-05-2020, 11:27 AM | #5 |
06-05-2020, 11:44 AM | #6 |
Drives: 15 Camaro SS Join Date: Oct 2018
2.5" will help and Corsa sounds amazing. Especially when cammed
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
09-18-2020, 08:11 AM | #7 |
Drives: 2011 Camaro SS Join Date: Jul 2019
Just get the Corsa. That will solve all your problems plus your getting the best exhaust you can by for the 5th gen imo.
09-18-2020, 08:34 AM | #8 |
Drives: 2015 2SS/RS Vert Join Date: Jan 2019
Yep, the j-pipes seem to make all the difference. Been through several engine mods and still no drone at all.
Proud member of the Motor City Camaro Club.
09-18-2020, 11:35 AM | #9 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
Lowering it didn't help , as said get it up on a lift and see where it is hitting/scraping .My guess is you can adjust it so it doesn't . I have Stainless Power 1 7/8 long tubes and an MBRP 3 inch system , and it doesn't scrape anywhere .Kooks is a top shelf company and one of the best 5th gen Header manufacturers in the biz. They should fit perfectly .
OLD GUY FLYING FAST AND LOW
09-18-2020, 02:12 PM | #10 |
I have the Stainless Power 1 7/8 LT's and a Flowmaster ZL1 Outlaw 3 inch catback on there and am lowered 1.5 and doesn't scrape anywhere, even speed bumps. My guess is that a clamp or something is dragging to cause this. Those headers also are the top notch units used by a lot of folks and should be tucked up nice and tight, mine are. Good luck.
06-28-2021, 06:16 AM | #11 |
Started#gottalovethatblue
Hope hard are you hitting bumps on the highway?! Even with a 3" exhaust and lowered you shouldn't be scraping. Perhaps if the tunnel brace is still there you're bumping it with the exhaust on big bumps. Stainless Works includes spaces for the brace in their kits.
If you like the sound of your exhaust, but hate the drone give Solo a shout and get some J pipes welded in. If you're dead set on changing your exhaust I am a fan of Solo's Mach XL catback. Corsa is great too for a no drone system as well, but it always sounded a little exotic for me where Solo was more classic muscle car, IMO.
07-13-2021, 02:09 PM | #12 |
Drives: 2015 2SS White Convertible CE/INDY Join Date: Mar 2016
My 1 7/8 ARH LTH run extremely low... its not hitting the ground but I have issues with my middle brace no longer fitting (the verts have a middle brace). Seems that I'm sorta screwed with brace until I can find a guy that could build something to replace it.
joe...
ARH LTH/HFC/Legato muffler, RDP Custom Tune, K&N Blackhawk CAI, Bigworm Blackout kit, ZL1 Rims, Phantom Grills, VMAX PTB
07-14-2021, 11:02 AM | #13 |
I never started scraping until I lowered mine, but I lowered it a lot. Now I only scrape on the highway when doing over 75, exactly like you mentioned - those long swooping dips. I must have hit it hard or maybe hit something else, because my passenger side cat delete/Off-Road pipe is partially caved in. It looks kinda like it was flattened, but it is still sealed, so I haven't swapped it out yet.
I am just lucky that there is some 'give' in the exhaust, or I would be very worried about it snapping bolts at the head and causing bigtime issues. So now on that stretch of highway I keep it under 75mph.
