09-24-2020, 09:20 AM | #1 |
Drives: 2013 Camaro 2SS/RS Join Date: Aug 2020
Cargon cleaning help
What is the best way and how ofted do you carbon clean your engines?
09-24-2020, 09:27 AM | #2 |
Drives: 2010 SS/RS M6 BIG cam Join Date: Mar 2016
Step 1 put transmission in 1st gear
Step 2 depress clutch Step 3 apply generous amount of throttle Step 4 release clutch Step 5 row gears like you were white water rafting Step 6 repeat daily That concludes the carbon cleaning tutorial
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
09-24-2020, 09:44 AM | #3 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
09-24-2020, 10:22 AM | #4 | |
Lesson 2 would then be for the automatic. Please provide. |
09-24-2020, 11:10 AM | #5 |
Start car, put trans in sport mode,tap downshift buttondo it shows m1,, turn off all nannies, hold the brake then romp the throttle and hold the brake kinda riemly, at 6k tap the upshift to second gear, manual mode still rev to 6k then take your foot off the brake and let her rip!! Do this once or twice and your good !!! Then go to get new tires for the rear after many of these. lol
09-24-2020, 12:28 PM | #6 |
We really don't have a carbon issue on the LS3/L99. It's the LLT/LFX direct injection V6 guys that need to stay on top of this.
Our valves tend to stay clean by design of port injection. Just install a catch can, run a quality high octane fuel, and change your oil often.
09-25-2020, 10:58 AM | #7 |
Sporting Foole
Drives: 2010 Camaro SS Join Date: Sep 2019
Italian tune up - crank it cold and peg it to the floor. Let it bounce on the rev limiter for a couple of seconds then proceed normally on your way.
