09-26-2018, 05:04 PM | #1 |
Drives: 2013 zl1 Join Date: Aug 2018
Can you add a/c on z28
Getting a good deal on z28 but has no A/c. Can it be added? And what parts do you need. ?
09-26-2018, 05:17 PM | #2 |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
Lots of parts are needed but it can be done, have to remove the dash, to replace the heater box with an evaporator box, and you will need to have the BCM reprogrammed for the AC to work and last a radio face plat that has AC controls on it.
09-26-2018, 05:45 PM | #3 |
Drives: Z/28 Join Date: Jan 2015
Not worth the hassle - I'd just try to find one with AC if I were you (if you absolutely must have AC).
09-26-2018, 05:57 PM | #4 |
Jumanji
Drives: '14 Z/28 - AGM - No A/C Join Date: Mar 2014
When i looked at adding it to my no-AC car, it came down to getting all of the OEM parts to do it right. The juice is not worth the squeeze IMHO. Either live with the cool factor of no A/C, or get one with A/C.
Keeper of the 5th Gen Z/28 Registry.
Registry Facebook. Follow: @5th_gen_z28_registry I track wrecked Z/28s Total lost -41 |
09-26-2018, 06:31 PM | #5 |
How can I check if car had a/c before maybe they took it off car has built motor.
Vin 2g1fz1ee9f9700973 |
09-26-2018, 07:49 PM | #6 |
Jumanji
Check the dash. Itll have a little snow flake on the cold side of the selector dial. Also, there are plenty of Z/28s with built setups which retained the A/C. Removing that system is a shoddy old school hot rod practice.
09-26-2018, 08:01 PM | #7 |
Is there a way to check with the vin number
09-26-2018, 08:15 PM | #8 |
Drives: 2015 Z/28; 1969 Camaro SS Join Date: Nov 2015
Contact your favorite Chevy dealer and they can give you the build details with the VIN.
09-26-2018, 08:53 PM | #9 |
There are vin decoders online that allow you to check options
I've used this one in the past: https://www.northamericanmotoring.co...vindecoder.php |
Thread Tools | |
