01-26-2020, 09:27 AM | #1 |
Drives: 2012 Camaro LS3 2SS Join Date: Oct 2018
LS3 RWHP Dyno Question
Hey guys, a couple of questions regarding LS3 RWHP Dyno numbers.
What would RWHP typically be for an SS LS3 Stock? Seems like I have seen 373-383 RWHP. Also, what would RWHP typically be for the same SS LS3 with long tube headers, HF cats, X-pipe, cold air intake, and tune? This is where I have seen a lot of variation regarding numbers. With this setup (see mods below), the dyno report from my tuner showed max Torque 439, and Max HP 438. Does that seem accurate? I realize different dyno's and temp makes a difference, thanks for the input.
Z/28 Cold Air Intake; ARH 1 7/8 Long Tube Headers, High-flow Cats, X-Pipe; Borla ATAK; 160 Deg. Thermostat; Craven Tune
01-26-2020, 09:58 AM | #2 |
Mine had weird numbers on a dynapack. 383 / 385 (give or take a couple) with CAI, 417/418 after LTH and tune.
Numbers aren't 100% accurate but pretty close. Can't find the darn print out anywhere... I did ask for a tune for the track, with more average power than peak in mind, but that doesn't really explain the baseline run which was CAI + a remote tune, the follow up LTH was tuned on the road and dynapack by Aikman.
468, Mishimoto rad + oil cooler, TSP LTH
MCS 2WNR CTSV/ZL1 front calipers/rotors + G-Loc Forgestar CF-5 19x11 |
01-26-2020, 10:39 AM | #3 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Mustang dynos read less than Dynojet. Bone stock on a Dynojet in the dead of winter, my LS3 was 355 hp. As the 2013 was the first year with electric power steering assist, I would imagine 2013 hp would be slightly higher than 2012 with a power steering pump.
01-26-2020, 11:19 AM | #4 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
To see a true gain you would have to run a baseline, then mod and run it again on the same exact dyno. Take the numbers with a grain of salt, they are a tool to measure gains. The number can't fluctuate a LOT between dynos. Mine ran 575 at jannetty, then a few months later i did a dyno day more to hang out with ppl at slowhawk, his mustang dyno showed 595hp and 5 less torque and everyone says mustang dynos read lower. Grain of salt.
01-26-2020, 02:56 PM | #5 |
Grumpy Grey-haired Guy
Drives: Camaro, Corvette & Merc C300(daily) Join Date: Aug 2014
Figures seem reasonable; I'd say that's about right.
01-26-2020, 08:40 PM | #6 |
Stigs Bahraini Cousin
I made 410 whp with drop in air filter and cat delete.
My friend made 410 whp with airaid cai, pacesetter 1 3/4 LT headers and x pipe Mine is 1LE his is not and he put 2 cars lengths on me. Both same tuner same dyno and he tuned in a better weather condition.
2015 CAMARO 1LE
02-13-2020, 10:09 PM | #7 |
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
i'm going to point at the elephant in the room,mustang is just a bad choice of a name for something used to measure power..
02-14-2020, 11:14 AM | #8 |
Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
In September of 2009 after Kooks LT headers, hi flow cats, ported intake, Rotofab CI and dyno tune on a DynoJet, RW/HP was 414 and RW/TQ was 406. In 2010 after S/C on same dyno readings were RW/HP 546 and RW/TQ 521 with 11# boost.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
02-14-2020, 12:54 PM | #9 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Every vehicle will respond differently to a tune. Numbers will be what they will. Whats more important is that a competent tuner gets the most out of your tune.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
