06-24-2018, 02:04 PM | #1 |
Drives: 2011 Join Date: Jun 2018
2011 cat back system an check engine light on
New guy to the site, I just purchased a 2011 camaro v-6. It has a cat back system on it. After about three days the check engine light comes on. Guy I bought it from says it needs a “spacer” in the O2 sensor. Anyone know about this, or possible soulutions? Any help is greatly appreciated.
06-24-2018, 03:06 PM | #2 |
USA-1
What code does it have?
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
06-24-2018, 03:23 PM | #3 |
P0420
06-24-2018, 06:49 PM | #4 |
USA-1
Ok...did you replace the o2 sensor?
06-25-2018, 12:24 PM | #5 |
No not yet, the guy said it came on three days after the system went on. I will just replace it an see. Car has 90,000 miles on it so it could be bad. I just never heard of this spacer he said they make that doesn’t allow the sensor to go all the way into the exhaust pipe.
06-25-2018, 12:53 PM | #6 |
Drives: 2011 2SS/RS M6 Join Date: Oct 2015
If it's a catback, you don't need any spacer. The cats are factory and so are the o2 readings. He sold you a car with a bad cat.
06-25-2018, 12:55 PM | #7 | |
Drives: 14 Silverado LTZ 4wd 5.3 Join Date: Jul 2012
Some of the newer app code readers allow you to log the signal on the o2s and see if they are working like they should. Probably start with that or just replace the o2. How close is the catback connection to the rear o2s on the 5th gen? Mostly a 4th gen guy learning the platform, looking at getting a 1le in next year or 2. |
06-25-2018, 01:36 PM | #8 |
Drives: 2013 Camaro 2SS RDP Tuned L99 Join Date: Apr 2013
To me catback means the system is replaced behind the cats. In other words the O2's should not be affected in any way. It makes me think he did something more than that to the car? Or there is something else wrong and that was just an excuse........
06-25-2018, 02:01 PM | #9 | |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
alternatively you could have stock mid-pipes installed
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
06-25-2018, 02:12 PM | #10 | |
Ret AF, cancer survivor
Drives: 2013 Camaro 2SS/RS & 2006 Corvette Join Date: Jul 2015
Installing a Cat or Axel back exhaust will have no effect on the O2 readings. The person who sold you the car knows this and sold it to you with at least one bad cat.
06-25-2018, 04:15 PM | #11 |
Great. Well I know their are cats that are coming off the manifolds by the firewall, I saw the o2 sensors there, is there 02 sensors and or cats past the ones at the firewall?
06-26-2018, 11:07 AM | #12 |
Anyone?
06-26-2018, 11:11 AM | #13 |
Not sure if this helps or not, but there should be two sets of two O2 sensors; one pre-cat and post-cat on each side of the exhaust. Not sure where they are physically located in reference to the firewall (haven't been under my car and really looked for the sensors).
06-26-2018, 11:24 AM | #14 |
Drives: 2010 2SS/RS L99 Join Date: Oct 2015
I have both stock cats I’d sell you. My car is a 2010 SS so I’m not sure if they’d work for you or not, but if so let me know and I’ll get em shipped out.
