03-12-2010, 05:40 PM | #1 |
Drives: 2SS/RS SIM -- Lifted 99' GMC Join Date: Jan 2010
Lowering suspension will void warranty?
I was wondering if putting on the Eibach lowering springs would void the warranty in any way? Complete void or just a void of the suspension, I have herd both so if anyone can clear it up for me i would greatly appreciate it!!!
Thanks |
03-12-2010, 05:51 PM | #2 |
Drives: 1969 and 2010 Camaros Join Date: Oct 2008
Mods will only void portions of the warranty directly affected by the part itself. Suspension mods will likely just void part or all of the suspension warranty. If you lose something unassociated with the shocks then it's a crap shoot to see if they'll cover it. They have to prove the mod you did caused the failure.
Planetlsx.com online magazine rep
03-12-2010, 05:51 PM | #3 |
Drives: 2013 SVT Raptor, sold 2010 Camaro Join Date: Jul 2009
- Pfadt Suspension Package; Springs & Sways
- Brembo Brake Upgrade (Yellow); Courtesy Fesler Built - Custom Magnaflow Exhaust - Blacked-Out Bowties & RS Emblems, Front bowtie delete - Full Dynamat Extreme Trunk Coverage - Tinted side markers - Interior DSV Customs Leather Upgrades - Airaid CAI V2 - Forgestar F14 Gunmetal 20x9, 20x11 - Doug Thorley Shorties |
03-12-2010, 06:45 PM | #4 |
03-12-2010, 06:45 PM | #5 |
Just lower it, who cares...LOL
03-13-2010, 10:36 AM | #6 |
Booooosted.
These questions have been asked here a million times. With 11,236 different answers.
You need to ask your dealer. Just remember, they get paid wether it's a warranty item and GM pays them, or it's not, and YOU pay them. So they really don't have any good reason to lie about it. |
03-13-2010, 12:42 PM | #7 | |
I'll ask them asap |
03-13-2010, 12:53 PM | #8 |
Difference being MOST dealership rates are higher for NON-warranty work.
03-13-2010, 01:06 PM | #9 |
Banned
Drives: 2010 Camaro Join Date: Jan 2010
They just get less book time for the work.
03-19-2010, 01:28 PM | #10 | |
Drives: 1st through 5th gen Camaros Join Date: Sep 2009
Suspension mods won't effect warranty issues with drivetrain, electronics, interior, etc. If you lower your car and then something happens to a suspension component they may ask questions, but unless its directly related to the aftermarket part you should be in the clear... unless the service writer is a stickler. If you lower the car an extreme amount and then pull your exhaust off on a speedbump, well, you might have some trouble getting that covered. |
03-20-2010, 01:28 PM | #11 |
Drives: 5th Gen Rental Join Date: Aug 2007
GM dealers have very serious differences in opinions. There are dealers that will not do warranty work on your Camaro if you put just wheels on it or change the tires. Then you have a more progressive dealership that it would not matter.
The bottom line is the federal government has made the ruling by making the Magnessen/Moss Act. This act allows you to do anything you want. But if there is a problem, it is the requirement of the manufacturer to prove the component you install created the problem. Now in most cases this is really hard and expensive to do. One exception might be adding a Maggie or some other major hp enhancer. GM has tested the strength of the power train for max hp and torque. If you have a transmission failure and your hp exceeds the trans torque rating, then you have a problem. In the case of suspension upgrades, this will be pretty challenging to prove some kind of powertrain concern. Now adding coils with 40% or 50& stronger ratings to OE dampers and the damper fails, could easily be challenged by GM if the rating of the damper is exceeded. But there is no published info on the dampers. We have about 200 Camaro with our drop coils and have not had any damper failures. I have heard of a couple from some other coil companies that have a lower drop than ours. But we have tested the OE dampers and they can handle our coil travels and rates. But we have limited the drop of our coils due to the info that we have accumulated on these dampers. mike dms |
Similar Threads | ||||
GM / SLP ZL 575 warranty debate | camaro1 | 5th Gen Camaro SS LS LT General Discussions | 57 | 04-25-2010 03:05 PM |
Magnuson-Moss Warranty Act | Eduk8r | 5th Gen Camaro SS LS LT General Discussions | 7 | 02-15-2010 07:21 PM |
what would void a warranty ? | mikeSS | 5th Gen Camaro SS LS LT General Discussions | 14 | 12-05-2009 09:43 AM |
SS Basic Upgrades? | Mod4SS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 58 | 08-10-2009 05:01 PM |
Will the V6 have DBW or a good old fashioned cable throttle? | theholycow | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 41 | 08-02-2009 08:25 PM |
