#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > V8 LT1 Engine, Exhaust, and Bolt-Ons
Old 09-12-2023, 03:33 PM   #1
carlythecamaro
carlythecamaro's Avatar
Drives: 2017 Camaro SS
Horse power gains from a ported throttle body?
Hello all, I have 1 7/8 in long tube headers and a K&N cold intake. I was looking into getting a ported throttle body and making sure the car is properly tuned. Would I notice any difference in the car if I did this? Thanks
carlythecamaro is offline   Reply With Quote
Old 09-12-2023, 03:57 PM   #2
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Better off with an OEM 95mm TB if you need more airflow than the stock 87mm one. Super easy to tune and better performance than a ported 87.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
Joshinator99 is offline   Reply With Quote
Old 09-12-2023, 07:25 PM   #3
carlythecamaro
Could you post a link to it?
Old 09-12-2023, 09:13 PM   #4
Joshinator99
Believe this is the one:
https://www.gmpartsdirect.com/oem-pa...bC12OC1nYXM%3D
You’ll need this too:
https://katechengines.com/i-30497839...m-to-87mm.html
Old 09-12-2023, 09:24 PM   #5
carlythecamaro
Will these two items be the only thing I'd need to complete the instal?
Old 09-12-2023, 09:25 PM   #6
Joshinator99
Aside from gaskets & bolts, yep.
Old 09-13-2023, 06:02 AM   #7
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
I have a 95mm zr1 tb ported to 100mm by solar with an adapter plate to a ported lt1 manifold if you are interested. It will bolt to unported lt1 manifold as well, just miss out on a little extra air. Been lazy and haven't posted it up yet, figured I'd throw it out there.
Booher is offline   Reply With Quote
Old 09-13-2023, 07:08 AM   #8
adamjwilson
Drives: 2022 Camaro 2SS A10
I have a Soler 95mmTB, adapter , and controller if interested.
2022 Camaro 2SS/ Whipple 3.0 / 2"Headers/ PRC LTX Heads/ Forged Internals/LT4 fueling/ DSX Aux/
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods
adamjwilson is offline   Reply With Quote
Old 09-13-2023, 01:39 PM   #9
Spudsmaro
Drives: 2021 LT1 6 SPEED MANUAL CAMARO
Get the 95mm throttle body from rock auto it’s under 2019 corvette zr1. It’s $200+shipping and taxes. Also get a lt2 intake manifold from rock auto as well about $200 too. You will need a tb adapter I personally went with the solar performance adapter ($70 on ebay) because it opens up to allow the 95mm tb plate to pass thru without any contact. Not sure about Katech but I’m sure they have just as good quality.
Compared to the msd being roughly $1500 and a Nick Williams tb being roughly $800
I’d say $460-$500 for just about the same gains is well worth it.
#budgetbuild
Spudsmaro is offline   Reply With Quote
Old 09-14-2023, 06:40 AM   #10
wnta1ss
Drives: 2017 Camaro 1SS
Honestly you'd likely gain very little hp, if any, from the ported 87. I had a v-max ported 87, and I did not see any gain from it, which agrees with a dyno test that I know of (zero hp gain). Other members have posted dyno tests of ported 87s, one reported a 2hp gain, and another reported a 0.5hp gain.
Comment on putting a 95mm onto the LT1 manifold with a restrictor plate like some of these guys are suggesting. Choking down the 95 by putting it onto an 87mm hole would mean that it's then not acting like a real 95 anymore. Meaning that you would not get the full potential from it. The proper way to use a 95 is with a manifold entrance that is large enough not to block it. This can be done with an MSD manifold (has 103mm opening) or an LT2 manifold that is max-ported by hogging the entry out past the o-ring groove (so then would need to make a gasket for the t/b because the o-ring is now gone). WITH a proper manifold for it, then yes, the 95 is good in my experience.
wnta1ss is offline   Reply With Quote
Old 09-14-2023, 07:59 AM   #11
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
As mentioned above...anything larger than a ported 87mm gains you little on a stock manifold. The intake manifold opening has to be opened up to the same size as the larger throttle body to see any real gains.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP
Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA
KingLT1 is offline   Reply With Quote
Old 09-15-2023, 03:03 PM   #12
carlythecamaro
#budgetbuild
I was debating on going with the MSD but if I would see the same results I may as well go with the LT2
Old 09-15-2023, 03:07 PM   #13
carlythecamaro
If I get the 95mm what would be the better option, the MSD or LT2? Ive read that the same HP can be gained by using either the MSD or LT2
Old 09-15-2023, 03:30 PM   #14
6spdhyperblue
Drives: 6th gen
With the current options available I’d only go 103 with the msd. The lesser plenum volume likes the inlet flow as well.
I’d go ported 87 or stock 95(ported throat on intake) with the lt2
‘22 2SS 1LE M6 Summit White - RF, Flexfuel, LT2 intake, 95mm tb, ATI udp, VT ramair, full 28” dragpack - 11.68@122
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold)
6spdhyperblue is offline   Reply With Quote
headers
