09-06-2012, 12:25 PM | #1 |
Jan
Drives: 2010 Camaro 1LT Red Jewel tintcoat Join Date: May 2010
Any problems after Black Iceolator install?
I was just wondering if anyone has had any problems with their Camaro after installing the Black Iceolator that seem to have been caused/contributed to by the install?
09-06-2012, 12:45 PM | #2 |
Drives: 1997 30th Ann. Z28 & 2010 2LT RS Join Date: Jan 2010
I've installed a few myself without a single issue . All cars still running fine .
09-06-2012, 02:16 PM | #3 |
no, real easy 30 minutes or less. just be careful when you go to retorque the bolts. and let the RTV set.
09-06-2012, 02:36 PM | #4 |
Drives: like a bat out of hell Join Date: Jul 2011
No problems here. You will be in for a surprise after the install. It was a day and night difference in performance.
09-06-2012, 03:16 PM | #5 |
Jan
Thanks. Hubby is really anxious about this & he is making me get anxious now. Any & all further input will be welcome.
09-06-2012, 03:20 PM | #6 |
Drives: 2016 SS w/2SS A8 Blue Velvet Join Date: Dec 2009
Had mine on since around late November, early December, whenever they first came out and all has been good. Just an adjustment so the cover will fit properly but its all good!
Never grow up, it's a trap!
09-06-2012, 03:24 PM | #7 |
Jan
I plan to just leave my cover off & work on improving the look of the engine & engine bay without it.
09-06-2012, 03:42 PM | #8 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
You'll be unplugging the throttle body on the front of the IM to remove it Ruby, (you don't need to take it off, but take it out with IM) and that almost always triggers a CEL. So don't let that freak you (or hubby) out.
You could disconnect the battery to reset it, or just drive awhile and it will clear on its own. Otherwise its a straight forward install and well worth the effort! |
09-06-2012, 03:43 PM | #9 |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
No problems with the install. Just remember the long bolts only need to be torqued to 18lbs when you put it all back together. I recommend checking them again after you've driven the car a few times...but do no retorque them when the engine is hot! Wait until it is fully cooled.
Also, a 13mm ratcheting swivel head wrench is a super thing to have for the removal to get to the two small bolts in the back of the intake. You will want this. If you need detailed instructions, I have them. PM me your email address and I can try to send over the instructions. It is kind of a large file though. last person I sent it to had some trouble receiving it, but eventually he got it.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
09-06-2012, 04:45 PM | #10 |
Drives: 2010 Camaro 2LT V6 Join Date: Jul 2009
Im installing the black ice this weekend as well, I will pm about those instructions. Thanks
Injen CAI, V-Max Throttle Body, Rx 25mm Iceolator, Rx 10mm Plenum Spacer, Mace Ported Manifold, ARK N-II Catback, Trifecta Tune, Rx Catch Can.
BMR Bushing Inserts,Pedders Radius Rod Inserts, Pfadt Sway Bars and Endlinks, LSR Front Subframe Brace SS Brembo Brakes, Racing Brake Stainless Lines |
09-06-2012, 05:37 PM | #11 |
[COTW 4/13/15]
Drives: Supercharged LLT Join Date: Jul 2010
The only problem you'll have is.....the muscles in face being sore from the added Permagrin
Edit: I would suggest using a extra manifold gasket, so you can avoid the mess of the rtv and etc. but isn't necessary
09-06-2012, 05:39 PM | #12 |
Nope, none, nada.
IPF supercharger kit, IPF tune, SW LT's, R. Tech HFC's, ARK DT-S catback, SS Brembo brake upgrade, BC Racing adjustable coilovers, Hurst STS, Pfadt rear arm package, Pfadt adjustable sways & end links, Pfadt diff bushings, BMR rear cradle full kit blk bezels,SS diffuser, Innovate gauges.
09-06-2012, 07:54 PM | #13 |
having FUN now 13.66@101
No problems with my install.
Only caution I have is the torque specs for the bolts. BE CAREFUL.
09-06-2012, 10:35 PM | #14 |
Just finished the install and i really did not want to do it but i am glad i did now. It was not that hard of a install no CEL or anything.
