Old 11-05-2015, 08:53 AM   #1
Soybeanrice
Soybeanrice's Avatar
Drives: 2014 2SS/RS
Driver side upper control arm bushing
Does anyone know how to loosen the bolt without taking out the cradle?? Its like impossible. Has anyone does this? I'm retiming the bushings..
Soybeanrice is offline   Reply With Quote
Old 11-05-2015, 11:49 AM   #2
rockrau
rockrau's Avatar
Drives: 2010 2ss red LS3
If you didn't take it apart you don't need to time it.
Pedders Pace Car Kit with ZL1 sway bar conversion & camber bolt kit.Lowered 1.5". 1LE tires & wheels. CAI air intake. Anvil CF rear spoiler.MGW shifter. 1 7/8" Kooks LT headers & HF cats.V-Max ported TB. Tuned.
rockrau is offline   Reply With Quote
Old 11-05-2015, 12:48 PM   #3
Soybeanrice
Drives: 2014 2SS/RS
I read on here that when you change ride height you need to retime the entire suspension. I did everything so far but the driver side upper control arm and the ride quality is definitely smoother... just didnt want the upper control arms to be uneven since i did the pass side.
Old 11-05-2015, 01:51 PM   #4
digdeep0169
digdeep0169's Avatar
Drives: 2012 Camaro SS 45th Anniversary
your correct. "clocking" or "timing" the bushings is recommended if suspension is altered. otherwise they're "pre-loaded" to previous suspension height.
~ 2012 SS ~
digdeep0169 is offline   Reply With Quote
Old 11-06-2015, 09:17 AM   #5
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
You need more grunt. Try a breaker bar.
Old 11-06-2015, 09:43 AM   #6
xc_SS/RS
Drives: 2010 Camaro SS/RS
Or a long section of metal pipe on the end of a breaker bar. I use a 3ft piece of gas pipe on a breaker bar. Haven't found anything that can't be broken loose yet!
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 11-06-2015, 10:49 AM   #7
Soybeanrice
Drives: 2014 2SS/RS
Its not the breaker bar. I cant get the drive into the socket because the chassis is blocking it... It balloons on the driver side, but not the pass side.
Old 11-06-2015, 11:00 AM   #8
JusticePete
Use a box end.
Old 11-06-2015, 03:21 PM   #9
xc_SS/RS
Get some ratcheting wrenches. You'll thank me later.
2010 2SS/RS
