12-25-2015, 03:54 PM | #1 |
No regrets the red one!
Brembo Caliper Bolts
I could swear that I read in a thread here on Camaro5 that the Brembo Caliper Bolts need replaced once the calipers are removed during maintenance? I cannot find the thread I saw this in, so can anyone confirm this for me?
StainlessWorks LT (JetHot Coating) + HFC + Performance Connect, 3" SW Retro Cat-back, Roto-Fab CF CAI, Bo White PO TB, R1Concepts Drilled-Slotted Rotors, Hawk Ceramic Pads, AirLift Performance 3H suspension, MPD1 Rear Spoiler, Heritage Grill w/ Red SS Sparks Emblem, SLP Front Splitter, NightOwl V2 Halo Kit, Roto-Fab Red Engine cover w/ CF Plenum & Fuse Box Cover
12-25-2015, 04:39 PM | #2 |
Drives: cars Join Date: May 2011
They're torque to yield bolts but many people have used blue loctite instead of replacing.
12-25-2015, 04:58 PM | #3 | |
12-26-2015, 12:34 AM | #4 |
KaBoom1701
It kills me every time I read one of these post....
You'll spend $$$$ on mods for your car but you don't want to spend $8 to replace the caliper bolts that hold your brake calipers on and help stop your car...... I don't get it.....
Mods:
12-26-2015, 08:49 AM | #5 |
Drives: '13 2LT/RS Twin Turbo Join Date: Aug 2012
I've had my calipers off tons of times, still using my factory bolts. As long as the threads look ok and uniform and they don't look streched then I'm fine with them.
3.6L Twin Turbo V6 Garrett GT28 turbos -- Jacfab forged connecting rods -- Diamond forged pistons(10.5:1) -- Alky Control Methonal Injection -- CircleD 2E triple disc torque converter -- BMR suspension 10.75 @ 131mph |
12-26-2015, 05:06 PM | #6 |
No, I never said that I wouldn't replace them. I hadn't realized that blue Loctite was an option but I plan to actually replace the bolts. I agree with you, that safety is far more important.
12-29-2015, 04:34 PM | #7 |
Drives: 2010 2ss red LS3 Join Date: Aug 2011
Bolts are Torque To Yield, meaning when they are properly tightened to specification it is also their yield point(stretched) never able to be stretched again....becoming worthless!
Pedders Pace Car Kit with ZL1 sway bar conversion & camber bolt kit.Lowered 1.5". 1LE tires & wheels. CAI air intake. Anvil CF rear spoiler.MGW shifter. 1 7/8" Kooks LT headers & HF cats.V-Max ported TB. Tuned.
01-02-2016, 10:54 PM | #8 |
30ftlbs +90deg for SS
01-03-2016, 12:10 AM | #9 |
Drives: 2015 Camaro 2SS Green Flash Edition Join Date: Dec 2015
Stupid application for torque to yield. I'm surprised that ARP hasn't jumped on this yet.
01-03-2016, 12:26 AM | #10 |
ya i wish
