10-18-2014, 10:36 PM | #1 |
Buzz after wideband
I just finished installing an AEM wideband and AEM boost gauge in my pillar. Both gauges are connected with an add a circuit to one of the auxillary 20A switched fuses in the fuse panel. If i remember its F17 or F18.
My setup looks exactly like what is mentioned here including my ground location: http://www.camaro5.com/forums/showth...fuse+panel+tap I am currently getting a very slight buzzing sound through my speakers. Both gauges are hooked up to the same fuse tap and also the same ground. The buzzing did not happen until i physically hooked up the wideband o2 sensor to the gauge. I also have been running a JL XD400 amplifier. I tried moving the ground to just locations around that fuse panel, and nothing seemed to change. I also moved my amplifier ground (currently grounded directly to battery), and again no change. Do i need to find a different ground location for the gauges? Should i try separating my boost and wideband grounds? What about a ground loop isolator for my amplifier? If anyone has had a similar situation, what did you do to resolve it? Thanks,
2010 1SS/RS LS3 M6
Edelbrock E-Force Supercharger, 3.00" Pulley, Roto-Fab CAI, Stainless Power LT Headers, LPE Dual Fuel Pump, ID850's, Custom Grind Cam, Katzkin Leather/Suede Interior 630RWHP mustang dyno. |
10-19-2014, 11:05 AM | #2 |
I tried grounding the wideband directly to the battery and it didn't make a difference.
2010 1SS/RS LS3 M6
10-19-2014, 09:47 PM | #3 |
Tried ground loop isolators on the rca's for my amp...no difference
Removed the JL amp and put the factory one back in.... no difference The only other option i have is try running the power directly to the battery, but have a feeling it wont make a diff either. I talked to someone else on here, and they could never get it resolved either.
2010 1SS/RS LS3 M6
10-21-2014, 10:55 AM | #4 |
Drives: BWM Join Date: Oct 2014
