08-06-2018, 11:32 PM | #1 |
Drives: 2015 camaro ss ls3 Join Date: Mar 2018
Long vs short tube headers
What are your guys thoughts on long vs short headers? Is there any brands you guys recommend for 2015 camaro ss ls3
08-07-2018, 09:14 AM | #2 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
ROFL..you just opened up a huge can o worms...on your first post! Please research the forum..TONS of info...for me boils down to whether you have to pass emissions(like me), mainly a street car with frequent trips to the track and H/F cats...
your best bet is to contact a tuner...I use dynoSteve at RDP..https://www.rdpstore.com/..IMHO ANY mod should be coupled with a tune, give them a holler ASAP. Good luck! peace
08-09-2018, 12:28 AM | #3 | |
Drives: Supercharged 2013 AGM 2SS/RS Join Date: Oct 2013
Long story short: long-tube headers add real performance gains, but are illegal in CA. There's limited evidence that shorties add any real power at all, but can be legal (not all of them are, they require CARB approval). If you are doing the work yourself, or are already doing work on the car and thinking about also swapping out the stock headers for shorties while they are readily accessible (so incremental labor would be limited) then swapping could make sense. But I doubt the cost of parts and labor to install shorties on their own is justified from the the limited power gain (if any).
2013 AGM 2SS/RS
SLP TVS2300, Edge CAI, 3" Magnaflow catback, BC Racing BR series coilovers, HRE FF15's (20x10 square) with Michelin Pilot Sport 4S's, GM STB, BMR front and rear sway bars and toe links, Prothane subframe bushings and front control arm inserts, JDP rear upper control arm bushings, Elite Engineering catch can. Tuned by Cunningham Motorsports. 1967 Bolero Red 396 SS/RS Convertible |
08-09-2018, 10:00 AM | #4 |
Instagram: Sangstah
Long tube headers will always be better but being from California, I understand why the choice for shorty headers as I went that route as well. Shorty headers by themselves will make barely any power gain but if you go with a catless or high flow cat downpipe then you can make some power with a tune. The downpipes are not too bad to remove, so when smog time comes, just replace the downpipes with the stock cats and good to go.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
08-15-2018, 09:59 PM | #5 |
Drives: 2014 Camaro 2SS black Join Date: Oct 2017
So I literally just switched my manifolds bact to stock from having long tubes and no cats. The sound is definitaly louder and meaner sounding with the long tubes but at least the car doesnt feel to slow or bad. Like stated the long tubes are gonna give you real gains but its all dependant how legal you wanna keep it
11-03-2018, 01:14 AM | #6 | |
Drives: 2010 Camaro SS 6.2 Join Date: Sep 2018
The car feels lazy. . It does have a CALTUNELSX sticker on it so im assuming the previous owner had the car tuned. I just know nothing about what tune they did on it. Im also looking into getting it cammed and headers on it but I want to keep it smog complaint. Not because im afraid of it not passing when its that time of the year because you know being in Cali you can still pass smog without passing smog 😉 but what's holding me back is that if I ever get pulled over and they do the test on the car or if I get caught in a smog check point then there's no way out of it. |
11-03-2018, 02:36 AM | #7 |
Sure there is. Out of state tag.
416HP, 422TQ. Rotofab CAI, Dyno Tuned. ALP's and a V1. |
11-03-2018, 09:29 AM | #8 |
11-03-2018, 11:34 AM | #9 |
Pay attention to details
Drives: 2012 ZL1 Join Date: Aug 2016
Shorties.
Just curious if the shorty headers change the exhaust note with an NPP exhaust system? I here that long tubes with the NPP system sound amazing.
11-03-2018, 08:54 PM | #10 | |
2013 AGM 2SS/RS
11-04-2018, 11:03 AM | #11 |
I know there's carb legal cams but Everytime i tried looking for anything else like headers they usually ended up being not carb legal. Do you happen to know where is the best place to look?
11-04-2018, 01:22 PM | #12 | |
https://www.camaro5.com/forums/showthread.php?t=437263
2013 AGM 2SS/RS
11-04-2018, 11:57 PM | #13 | |
11-05-2018, 12:12 AM | #14 |
Drives: 2010 Camaro 2ss/Rs Transformers Join Date: Aug 2014
Long tubes for sure. I’m in California too.
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage LS3 conversion Vararam intake(tune model) Kooks LT headers & cats delete Corsa ZL1 3" exhaust RedBarn Racing Tune CMS Stage 3 Cam AFR CNC ported heads MSD Spark plug wires LNC-2000 Launch controller NGK TR6 Spark Plugs 1le strut tower brace-TPIS spacers Nick Williams 102mm throttle body Fast lsxr 102 intake manifold Slp 25% UDP Katech Tensioner Pulley Circle D 3600-3700 multi disk Stall GM 3.91 gears DDS carbon fiber driveshaft ZL1 fuel pump & injectors Flex fuel sensor(91/E85) https://wheelwell.com/kris-perez |
