06-15-2020, 03:46 PM | #1 |
Drives: 2015 2ss 1le Join Date: Jul 2019
JRE performance parts.
Due to certain circumstances I’d like to delete this post
2015 camaro 2ss rs 1le. jannetty blower cam,jannetty fuel controler, jannetty tune, 1050 id injectors, Kooks long tube's with zl1 corsa extreme exhaust. lsa conversion 14 lbs boost. roto fab intake. afco intercooler, Mcleod rst. hotchkis lowering springs.z28 rims, copo hood
06-15-2020, 04:54 PM | #2 |
Drives: 2012 ZL1 Join Date: Jul 2017
That's awesome! I agree, Ted does great work.
~ 2012 ZL1 - DynaTech 1 7/8" Headers - ID 1050 Injectors - E85 - DSX Aux Pump -
22.5% Crank Pulley - Roto-Fab CAI w/ Big Gulp- CJ/Jannetty Tuned ~ PB ET 10.54 |
06-16-2020, 09:14 AM | #3 |
Drives: 2011 Camaro 2SS/RS Join Date: Feb 2020
Glad to hear they fixed your bucking problem. Ted and his crew really are amazing at what they do. I'm lucky enough to only live 15 minutes away from their shop.
L99 to LS3, Whipple 2.9 Blower with 3.750 pulley, ID1050x injectors, JRE Rough Idle Blower Cam, BTR Bronze Bushing Trunnion Kit , JRE/BTR .660 Springs, BTR Pushrods, Melling High Volume Oil Pump, ZL1 Fuel Pump, JRE FPCM, JMS BAP, JRE 90MM Ported Throttle Body Circle D 3200 Stall Converter, Ceramic Coated Kooks Long Tubes, Kooks Full Exhaust with Hi Flow Cats, Cold Air Inductions Intake With JRE Scoop, JRE Built Rear Differential with Billet Caps, 3:91 Gears and Eaton TrueTrac Posi, JRE Dyno Tune, Moroso Wires, Moroso Catch Can, Factory Reproductions Gloss Black ZL1 Wheels. 659WHP/566TQ
06-16-2020, 03:05 PM | #4 |
Mauimax3
Ted's the shit.
Magnuson Supercharger, ZL-1 Fuel Pump, Kenny Belle Boost-a-Pump, Kook's LongTube, BTR Stage II, Trunion upgrade, ATI Superdampner, Nick Williams 102mm, Elite Eng. Can, Borla ATAK exhaust w/flow thru cats, CAI box. BMR Suspension upgrades. Dr Phil tuned.
06-16-2020, 04:31 PM | #5 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
This is freaky. I was just thinking about using him today to cam my car lol. Maybe I should call tomorrow.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
06-16-2020, 05:27 PM | #6 |
06-16-2020, 07:16 PM | #7 | |
06-16-2020, 07:58 PM | #8 |
Fingers crossed I may have just found my vacuum leak. When I put the corsa exhaust on the lines for my original npp exhaust hoses were not capped. I hope that is it. to late to look at data tonight but i will know tomorrow.
06-17-2020, 07:52 AM | #9 |
USA-1
And that was with a remote tune from Jannetty?
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
06-17-2020, 08:54 AM | #10 |
Well that was not it, if anybody has any suggestions on where I could be getting a vacuum leak I’m all ears. I have checked all the vacuum lines and removed the headers and re-torqued them and checked for exhaust leaks and I cannot find anything. Long term fuel trims at idle fluctuate from a 3 to about 7 back-and-forth but usually settle around a 6 to7.
06-17-2020, 08:57 AM | #11 |
Yes it is. He noticed that the numbers weren’t right while idling and said I had a vacuum leak. I’ve been searching and searching and cannot find it. Car idles perfect and wide-open throttle is perfect but I have nudging/slight bucking at 1700 to 2100. I can’t believe it’s this hard to find a damn vacuum leak lol. Sent from my iPhone using Tapatalk
06-17-2020, 08:58 AM | #12 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Intake manifold ? Check the brake booster hose behind it or the intake gaskets. I just installed the gpi intake and my brake booster hose in the rear was soft and will cause a leak soon.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
06-17-2020, 09:01 AM | #13 |
Thanks, I will try that. I checked everything upfront of the engine and everything seems to be fine, I may have cracked it or something
06-18-2020, 10:46 AM | #14 |
