Old 09-10-2013, 12:12 PM   #1
bigssc
Drives: Black 2013 Camaro 2SS (auto L99)
best cam for an L99?
What is the best one to go with? and do i need any supporting mods? can you still supercharge the car after the cam is done? i usually see guys either doing one or the other not both.
bigssc is offline   Reply With Quote
Old 09-10-2013, 12:27 PM   #2
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
pm Rhino for a VVT cam grind that works well with a blower.
Camarojt is offline   Reply With Quote
Old 09-10-2013, 12:42 PM   #3
62nalide
62nalide's Avatar
Drives: 2013 SS
^^^^ what he said.
62nalide is offline   Reply With Quote
Old 09-10-2013, 02:49 PM   #4
The Blue Ox
The Blue Ox's Avatar
Drives: 2010 SS L99 Inferno Orange
Also, check out Lethal Racing!!
The Blue Ox is offline   Reply With Quote
Old 09-10-2013, 02:56 PM   #5
BenningJ
BenningJ's Avatar
Drives: 2013 AGM 1SS/RS LS3
I know plenty of people that have done a cam and blower setup. Just make sure your builder knows that your goal is to have both and they will spec out a cam to match the blower. There are plenty of cams that will fit the job.
The ones suggested above are a good start but you might also want to expand your search to JRE and Livernois. Just to get a good idea of the numerous options you have.
2013 Camaro 1SS/RS - Ashen Gray Metallic
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R | BMR Polyurethane Motor Mounts
BenningJ is offline   Reply With Quote
Old 09-10-2013, 02:56 PM   #6
BLACK10
BLACK10's Avatar
What rwhp is your goal with the cam?
Old 09-10-2013, 03:05 PM   #7
Piccione Performance
Piccione Performance's Avatar
Drives: 2010 2ss/rs & 2014 Stingray
It depends on what you want out of the car. If your currently N/A and want a cam now and a supercharger later, if your already supercharged, or if you just want to stay N/A.
Are you an auto or manual, do you want a smooth idle or rough, how important is drivability to you?
You should at least have long tubes and a good cai.
You can supercharge after the cam but that will predicate what cam you go with.
My 10 SS has over 70k with both, its my daily driver.
PM me if your looking for something specific, we have several cam packages.
Piccione Performance is offline   Reply With Quote
Old 09-10-2013, 03:12 PM   #8
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
it's a money thing when it comes to both...that's the pill I'm trying to swallow. Honestly, I'd do the blower first. Converter and cam and blower type will be a trifecta for kill. All three have to work with each other.
-John S.
Old 09-10-2013, 04:01 PM   #9
bigssc
475 to 500whp
Old 09-10-2013, 04:45 PM   #10
Nightmare2012
come find out;)
Drives: stockish 2012 camaro ss
For that power range either contact rhino for his vvt cams or lethal they made bplumcrazy reach 500 with heads/cam
Nightmare2012 is offline   Reply With Quote
Old 09-10-2013, 04:48 PM   #11
MTI Racing Kevin
MTI Racing Kevin's Avatar
Drives: 2010 Camaro
Camshaft
Check out the MTI Racing Stage 1 Camshaft. This cam is designed to work with the stock converter and will work perfectly with a supercharger.
http://www.mtiracing.com/mti-racing-...10-camaro.html
MTI Racing Kevin is offline   Reply With Quote
Old 09-10-2013, 06:22 PM   #12
Johnthegreat
Johnthegreat's Avatar
Drives: 2012 2SS/RS black camaro
I dont mean to thread jack .What kind of power are those cams pushing? I'm in the market to. Pm me price please .
Johnthegreat is offline   Reply With Quote
Old 09-10-2013, 09:00 PM   #13
BenningJ
BenningJ's Avatar
Correct me if I am wrong but I don't think there is a cam out there that will net 475-500whp with an L99, even after doing a LS3 conversion, that will still be blower friendly.
Old 09-10-2013, 11:29 PM   #14
BLACK10
BLACK10's Avatar
We have made 470-480rwhp often with the NFC with ported heads and then made 700-800+ with the addition of a supercharger. It all depends on the hp goal of the project.
We have a specific list of parts needed to make these numbers after testing different combinations over the years.
Here is one example:
http://www.camaro5.com/forums/showthread.php?t=308123
