Old 04-02-2020, 03:36 PM   #1
737mechanic
Drives: 2013 Camaro
Blend air door replacement video
Hi guys, I had to replace the blend air door on my son's 2013 Camaro. If you don't know to do this right you have to remove the dash which also requires the windshield to be removed unless you cut the bolts. The dealer charges roughly $3500.00 to replace the $20.00 door.
A cheap workaround for this is to cut a hole in the side of the HVAC box to gain access to the door and allow you to easily remove it.
I made a video of this job in case any of you guys ever need to do this job.
It also shows the relearn of the actuator which should always be done when replacing the door or actuator.
5th Gen Camaro Blend Air Door Replacement Without Removing Dash
737mechanic is offline   Reply With Quote
Old 04-02-2020, 07:09 PM   #2
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Page bookmarked and thank you.
0stones0 is offline   Reply With Quote
Old 04-03-2020, 12:45 AM   #3
'10CamaroDude
Drives: 2010 Camaro LS
Just had another huge thread on that, and the FIX, so you don't break it again...
'10CamaroDude is offline   Reply With Quote
Old 04-03-2020, 06:35 AM   #4
Hulk
Hulk's Avatar
Drives: 2011 Synenergy Green 2SS/RS
Where is this thread?
2011 Synenergy Green 2SS/RS Automatic.
Hulk is offline   Reply With Quote
Old 04-04-2020, 01:38 AM   #5
'10CamaroDude
In the forums... I think there is a search feature, or something.
There is more than one, even one that says there should be a
recall because of it.
Old 04-08-2020, 12:30 PM   #6
uvraise
uvraise's Avatar
Drives: 2021 Camaro SS Convertible
Just watched the video, you made it look easy! I'm going to fashion a hot knife my self.
The question I have is, when you installed the new blend door, what position was the temperature dial in relationship to the door, on install? The door itself was obviously down, but is that the hot or cold position on the actual dial? Thanks!
2015 SS2/RS, SCT Tune (Dynosteve), Vitesse Throttle Controller, Vararam VR-DRX CAI, Vararam Power Wedge TBS, Granatelli Performance MAF
uvraise is offline   Reply With Quote
