10-11-2019, 04:56 PM | #1 |
V6 banger
Drives: 2016 Lexus CT200H Join Date: Apr 2017
steering wheel vibration at 60-70mph! *SOLVED!*
2013 V6 6spd car with 87k miles, stock suspension, and Platinum Widow 18x8 wheels with some hankook tires. with 80% tread on them. I've had the wheels balanced 2 times and i'm being told they balanced perfectly with no issues. But at about 57ish up to 70mph I start to get a heavy vibration from the steering wheel. And of course when i brake at that speed I feel even more vibration.
Bought the car with these wheels and some tires that were almost bald. put on new tires and could tell the brakes needed to be replaced in the front due to a little vibration at any speed and I was told by the original owner she never replaced them and i bought it at 60k miles. After I replaced the front pads with EBC red stuff (i've used EBC before never had any issues) and had the front rotors turned. After i drove the car a little i noticed the high speed vibration. drove like that for 10k miles because i had another vehicle and i was lazy . decided I thought the rotors were warped and i bought new EBC slotted rotors with a new set of red stuff pads. put it all together and the vibration is still there. Today i swapped the front tires with the rear (no name korean brand front tires with the hankooks in the rear) and vibration is still there. The tire guy swears its the rotors and pads, and i need to go back to stock. OR that i need a hub ring as there is plenty of movement from the rim when the car is lifted and the lugs are not torqued down... Anyone else run into this problem with aftermarket pads or rotors???
2016 CT200h (daily)
2017-2020 V6 (currently looking to buy) 2013 LS 6-speed (SOLD) Elite E2 catch can, CAI intake, 2.5" SLP Loudmouth II mufflers with no resonators with an X pipe, Kenny Racing ported TB, Jacfab spacer and ported manifold and Accelerated Racing E85 octane dyno tune = 300WHP Special Thanks to... Jason@JacFab, ChibBlackSheep, Kenny Racing & Accelerated Racing (use to be in) Rancho Cucamonga CA. Last edited by awdmofo; 10-29-2019 at 08:48 PM. |
10-11-2019, 06:36 PM | #2 | |
I literally just went through this...I had BOTH a blown out front strut AND bad Strut mount. When my mechanic put the Camaro on the alignment and lifted it, the passenger wheel dropped waaaay too fast. I got new front struts and mounts and the brake vibration is gone. The steering wheel vibration almost went away. it is so so slight now. But, I just got new tires put on today, the old ones wore out weird, mechanic said most likely due to blown mount and strut. Ill drive it tomorrow and let you know if vibration is completely gone. Message me if I forget to let you know.
SOLD: 2010 2SS/RS L99-A6 K&N CAI, Speed Engineering Long Tube Headers, Stainless Works hi-flow cats, Flowmaster American Thunder Cat-back. Tuned by Corvettes of Westchester. 1/LE rear suspension conversion, Bilstein B6 Stuts/shocks.
10-11-2019, 07:08 PM | #3 |
Drives: 2014 Camaro 2SS Join Date: Feb 2015
Rims could be bent, but not visibly. Ive also see tires that are only usable if they are road force balanced, some tires just don't want to balance out on a particular wheel, and just never balance out perfectly.
10-11-2019, 07:48 PM | #4 | |
V6 banger
vibration wasn't happening when i first got the car and i havent hit anything so i would assume its unlikely. The guy i use has been working on tires for 25+ years, never did me wrong. Showed me on some odd machine i've never seen that the tires are not out of round and balanced perfectly. I think it was the hub ring. I'll get all 4 replaced and chime back in.
2016 CT200h (daily)
2017-2020 V6 (currently looking to buy) 2013 LS 6-speed (SOLD) Elite E2 catch can, CAI intake, 2.5" SLP Loudmouth II mufflers with no resonators with an X pipe, Kenny Racing ported TB, Jacfab spacer and ported manifold and Accelerated Racing E85 octane dyno tune = 300WHP Special Thanks to... Jason@JacFab, ChibBlackSheep, Kenny Racing & Accelerated Racing (use to be in) Rancho Cucamonga CA. |
10-12-2019, 02:57 PM | #5 |
Drives: 02 Camaro B4C Join Date: Nov 2016
the top of the strut shouldn't move!
If it does you should get it repaired right away!
A man's garage is his castle
1969 Camaro SS 1970 Camaro SS 2002 Camaro B4C 2014 Camaro SS Dedicated Track Car 2015 Camaro 1SS 1LE 2008 HHR SS 1996 Silverado Crew Cab Long Bed Dual Rear Wheel |
10-12-2019, 04:44 PM | #6 |
376 cubic inches of fun
Well obviously the hub rings need to be replaced.
60 to 70 mph is the resonant frequency of the sprung mass of the wheel. If the wheels are unbalanced or de-centered, they will start bouncing up and down at that speed. Also if the struts are loose or broken, you won't get sufficient damping to limit the bouncing. If this gets bad enough, it will result in loss of steering control! So get a competent mechanic to evaluate everything. |
10-14-2019, 12:36 PM | #7 | ||
V6 banger
I'm not a mechanic on "paper" but i've been working on cars for 19 years now. Building a 1990 celica AWD turbo in my garage currently. I tore the engine down to the block so i think I can replace shocks, strut tops or whatever the issue is. This is just my first american car i've ever owned .
2016 CT200h (daily)
10-14-2019, 03:22 PM | #8 | |
Not true, It depends what kind of movement, these cars come from the factory with a gap, you can see it turn as the wheel turns. They should rotate. Update on my car with the new tires, mounted balanced, and all the new parts, that vibration is almost imperceptible. I have to think about it to feel. it.
10-15-2019, 12:05 AM | #9 | |
V6 banger
Thats good news . I think Rock-it Man might be correct about the hub ring because I totally could have thrown them aside while doing brakes and not even realized what it was. On that note i'm willing to bet $50 on it lol, I just bought some used stock 18inch black steelies that look to be in good shape. I'm thinking if I put the good hankook tires I have in the front onto them and take it for a spin I should be good. BUT, the car is almost at 88K miles so the shocks could be bad as well as the shock top mount.
2016 CT200h (daily)
10-15-2019, 10:31 AM | #10 | |
Sounds good, I would love to hear about if the hub ring and wheels fix it.
10-15-2019, 05:03 PM | #11 | |
V6 banger
Maybe my tire guy (yes tire guy) was right? could EBC slotted rotors and or the red EBC pads be causing vibration at 60-70mpg?? Going crazy trying to figure it out. As promised here are some pics of the tops of the struts at full clock, you can see the top raises just a little depending on which side you turn the wheel... This is the top of the passenger side shock when the wheel was turned all the way to the right (as if you were in the car) Same side with the wheel turned all the way to the left... This is the top of the driver side shock when the wheel was turned all the way to the left (as if you were in the car)
2016 CT200h (daily)
10-15-2019, 05:22 PM | #12 |
Sorry to hear the vibration wasn't fixed. THe strut top looks normal. Could be a problem internally in the mount or strut. Do you feel a clunk in the steering wheel when it is fully clocked and you go over a bump? My steering felt vague and clunked in slow speed bumps. Its fantastic now, so maybe its the strut and/or mount.
10-15-2019, 07:43 PM | #13 | |
V6 banger
2016 CT200h (daily)
2017-2020 V6 (currently looking to buy) 2013 LS 6-speed (SOLD) Elite E2 catch can, CAI intake, 2.5" SLP Loudmouth II mufflers with no resonators with an X pipe, Kenny Racing ported TB, Jacfab spacer and ported manifold and Accelerated Racing E85 octane dyno tune = 300WHP Special Thanks to... Jason@JacFab, ChibBlackSheep, Kenny Racing & Accelerated Racing (use to be in) Rancho Cucamonga CA. Last edited by awdmofo; 10-15-2019 at 07:56 PM. |
10-16-2019, 08:21 AM | #14 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
I don't think it's the pads, they don't rotate or come into play except when applying the brake. It could be the rotors are out of balance or not flat on the hub. If it was me I would jack up the car (very securely) pull the wheels off and mount the front wheels on the back and spin them to the speed that you are having the problem and see if the vibration follows the wheels. This is assuming the traction control will allow this, I haven't had to do this for 30 years. Tire shops used to have a machine that could spin the non-drive wheels to speed mounted on the car to try and isolate problems, but I don't know if they are still around, again I haven't seen one in about 30 years.
