05-11-2018, 06:58 AM | #1 |
YUDLOSE
Drives: Supercharged 2010 ABM 1SS Join Date: Aug 2011
Will these tire sizes cause issues
I have a set of 20x10 and 20x11 oem black zl1 10 spokes from a 2015 zl1. I ordered new tires from Nitto NT555 G2 front 275/40/20 and rear 315/35/20. The rear fit great but the front due to me being lowered 1.25 on pdfat springs it causing it to rub. I was suggested to order a set of 285/35/20 instead but come to find out they are on national back order with no ETA. I am going to the Camaro gathering next month in North Carolina and I have to get something but don't want to get a different brand tire as they have to be matching. Nitto in the G2 has a 275/35/20 and they have it in stock. My concern is the size difference in overall diameter if it is going to cause any issues with abs or stabilitrack. A long time ago I read if there was too much difference from front to back it could cause problems but I tried searching and haven't been able to find an answer. Does anyone have any info or are you running a 275/35/20 and 315/35/20 combo with out issues?
315/35/20 is 28.66in overall diameter and the 275/35/20 I want to order are 27.56in overall diameter. Thank you for your help.
Trey Jenkins 2010 Supercharged ABM SS Camaro LS3 #400 Order Number: NJGC85 Build Date: 06/24/2009 1996 Blue Z/28 Camaro 396 stroker in the process 1994 Red Z/28 Camaro |
05-12-2018, 10:22 PM | #2 |
YUDLOSE
Anyone got any info?
05-12-2018, 10:58 PM | #3 |
Drives: 2011 Camaro SS/RS Join Date: Jun 2016
I would suspect the smaller fronts would not play well with the stabilitrak system. Is there any way to make the 275/40 work? Roll fenders maybe?
2011 SIM 2SS/RS L99/A6, Rotofab CAI, TSP LTs & hi-flows, SW Retro catback, BMR & Hotchkis goodies, MRR 017s & Nitto 555G2s
05-14-2018, 12:22 AM | #4 |
BowtieBelle's SS
Drives: 2010 Camaro SS Join Date: Jan 2012
I’ve ran 275/35 all around and certain spots in the road caused suspension travel that would cause the service stablitrack. Race car mode is what I laughingly called it.
I now have the same wheels you do and have 285/35(1LE setup) all around. I have the rub you’re speaking of as well. Both tire setups I have been lowered on coil overs about the same drop as you. I can’t camber in anymore and am searching for a resolution for the front like you. My solution thoughts some far: Im considering putting 275/35 back in front and dealing with the fault tripping because they looked great. Fender rolling I don’t know anything about yet. Wheel spacer to allow more camber. Raising my coil overs slightly.
05-14-2018, 06:35 AM | #5 | |
YUDLOSE
I guess I am just going to have to try it and see what happens as I cannot seem to find anyone that has run this specific combo. Thank you for the info.
05-14-2018, 07:43 AM | #6 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
This will help you with selecting tires with proper sizes without getting the stabilitrac error.
https://tiresize.com/calculator/ |
05-14-2018, 08:11 AM | #7 | |
YUDLOSE
05-14-2018, 08:41 AM | #8 |
AKA "Beefcake"
05-14-2018, 08:44 AM | #9 |
AKA "Beefcake"
I will be running 285/35 up front and 295/35 in the rear.
05-14-2018, 08:59 AM | #10 | |
Pay attention to THIS.
2014 2SS/RS VERT L99 SUMMIT WHITE AIRAID CAI BORLA ATAK CAT-BACK EXHAUST ELITE ENGINEERING CATCH-CAN RANGE AFM-DELETE MODULE HUPER OPTIK 40 CHROME PEDALS PREMIUM FLOOR MATS PREMIUM CARGO MAT DEDICATED 32GB iPHONE HD[/I][/B][IMG][/IMG] |
05-14-2018, 12:59 PM | #11 |
YUDLOSE
I had already ordered the 275/35/20 tires over the weekend as I needed to get something going as with the national backorder with no eta it seemed like my only option. So if I do switch out the front tires and it does cause a problem. IS the big thing that the light for service stabilitrak will burn or is there more to it?
05-15-2018, 12:29 AM | #12 |
BowtieBelle's SS
I think service stalitrack just shuts off the nannies. I don’t ever notice any difference.
05-15-2018, 07:07 AM | #13 |
YUDLOSE
So I should see no issues other than the light being on your saying?
05-15-2018, 11:32 PM | #14 |
BowtieBelle's SS
Race car mode haha.
I didn’t notice anything.
