Old 05-10-2018, 09:54 AM   #1
trans665
trans665's Avatar
Drives: 2013 2ss
Copper spray BTR ls9 gaskets??
Just as title says....I'm having water blow by from the coolent Reservoir under high boost...just got them in and about to start replacing but I hear different things about the copper spray....thank you
2013 auto ss..full bmr suspension..3800 stall...s475 turbocharger on 16 psi with 150 nitrous outlet plate...,BTR stage 3 turbo cam.....100% Methanol injection....LY6 6.0 iorn block ...
trans665 is offline   Reply With Quote
Old 05-10-2018, 10:31 AM   #2
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
some do..some don't...lol...sorry I know it doesn't answer your q....better q for me is are you using head studs? also were the heads whacked for straightness and was the block checked?
stock ls3 heads? may need to step up to lsa/ls9 or after market if the above isn't enough...good luck!
peace..
btw - if you end up using the copper...spray both sides and let that stuff setup and get real tacky before installing! l8tr
Old 05-10-2018, 10:42 AM   #3
trans665
trans665's Avatar
Drives: 2013 2ss
ARP studs with LS3 heads but the regular LS3 head gaskets. Turns out the person that installed the heads did the driver side perfectly fine with 85 PSI but the passenger side was all 55 PSI. So the studs weren't the issue. It's the person that did the work
Old 05-10-2018, 11:10 AM   #4
Punisher_ATX
Drives: 2010 SS
FWIW i Copper spray all of mine. LS9's and studs
Punisher_ATX is offline   Reply With Quote
Old 05-11-2018, 08:31 AM   #5
Russell James
Russell James's Avatar
If the heads have been on/off multiple times... it'd be really good to get a machinist's straight edge and measure the end to end, corner to corner flatness. Anything other than near perfection, and I'd have a .005" clean up cut on them next time off. I've seen several people chasing headgasket issues with all kinds of tricks, when really the heads need a clean up cut. The really good long machinists straight edges are pricey, but it finds the issue instead of band-aiding it. The block deck also needs to be checked.
Along with - razor blade only gasket scraping. If someone has taken an air drill wizzy wheel scouring pad to either the block deck or head deck... it's toast. Those things destroy the factory machined flatness. Along with spraying aluminum bits everywhere that will tear up the bearings.
Old 05-11-2018, 10:03 AM   #6
go_go_gadget88
go_go_gadget88's Avatar
Drives: 2010 Camaro 2SS/RS ABM 6M
This is exactly why I did this by hand when cleaning deck/pistons when heads were off. Yeah a wheel would be 100x faster for cleaning the surface, but can eat into the aluminum pretty easy. Much less chance of having any issues with flatness if you scrub them down by hand.
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
go_go_gadget88 is offline   Reply With Quote
Old 05-16-2018, 10:38 AM   #7
trans665
trans665's Avatar
Drives: 2013 2ss
These heads have been off multiple times. I'm just going to order some GM MP LS3 Ported heads from summit racing to be safe.
