12-08-2018, 12:42 AM | #1 |
Drives: 2017 Camaro 1SS Join Date: Dec 2016
self-dimming mirror
So I decided to try swapping in self-dimming mirror into 1SS. Installed it and it doesn't power up. Connector wiring pinout is different between the two mirrors. Has anyone tried rewiring the connector to provide power to electrochromic?
12-08-2018, 12:38 PM | #2 |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
Are doing the out side mirrors to, making them auto dim?
12-08-2018, 12:42 PM | #3 |
I only want to swap rearview mirror to help with headlight glare. side mirrors don't bother me
12-08-2018, 06:07 PM | #4 |
Drives: 2018 SS 1LE Join Date: Sep 2018
Is it easy to swap to dimming mirrors for the sides and rear view mirrors?
12-09-2018, 06:16 AM | #5 |
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500 Join Date: Mar 2012
I wouldn't mind doing that to my 1SS as well but what about the cost and does the car need to be reprogrammed for that?
12-09-2018, 09:55 PM | #6 |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
Is it even possible to have auto dimming on the passenger side mirror? I thought this simply wasn't implemented.
(Despite what the window sticker said, I was silly enough to follow the hint on a GM parts site and order a "Right, Mirror, With auto dimming" part, which, upon inspection, it obviously isn't, but hey, at least I have a spare in case it breaks...)
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
12-10-2018, 09:02 AM | #7 |
Drives: 2017 Camaro SS 2SS Join Date: Jun 2017
I work for the company that manufactures these mirrors. We do not make the passenger side in that shape that is self dimming. If we did I would have one. lol.
Last edited by lokitwitch04; 12-12-2018 at 08:53 AM. Reason: We do make both mirrors. |
12-10-2018, 09:28 AM | #8 |
My side windows came tinted so I guess I have auto side dimming mirrors once my widows go up....lol, I would rather just have the inside mirror that auto dimmed.
12-10-2018, 10:17 AM | #9 |
so looking at the pin out your car has 5 wires missing to upgrade to the dim mirror, if your not going to run the outside mirror then your only 3 wires off, you will need to add battery positive to pin #8 next add Backup lamp control to pin # 1( this is so when your in R the auto dime goes off, and last you will need to add Low Speed GMlan to pin #6 if you dont do that no onstar in the mirror.
12-11-2018, 12:14 AM | #10 |
thanks for the advise. But which pins from my non-dim harness do I have to move or jumper to the ones you suggest?
12-11-2018, 06:34 AM | #11 |
Who Needs to KNOW?
Drives: 18 ZLE Join Date: May 2018
my 18 has auto dimming side mirrors, light sensor is built into rear view mirror, cover the hole and mirrors get really dark, as far as I can tell, sensitivity is not user adjustable.
ing for grip.
Are you in the NY/NJ/PA/CT region? Join us for autox fun at MetLife Stadium. HUGE lots, tons of runs. http://www.motorsportsne.com/ |
12-11-2018, 06:45 AM | #12 |
Pat
Drives: 2017 Camaro 1LT I4 Turbo A8 Join Date: Nov 2016
Tint your back windshield. Life saver. I have mine tinted 5%. It is legal in my state to have any percentage on the back window.
That will cost you about 30 bucks tops.
Follow me on Instagram @whiskeyfed
Subscribe on YouTube Whiskeyfed Camaro Follow my Build Thread The WhiskeyFed Camaro Current Modifications: JacFab Boost-O-Lator, Injen Evolution CAI, ZZP Catless Downpipe, RPM 3" Charge Pipe, Mishimoto Oil Filtration/Coolant Systems, R1 Concepts Brakes Package, Eibach Pro-Kit Lowering Springs, PTP Lava Exhaust Wrap & Turbo Blanket DYNO SHEET: 297whp / 374wtq Tuned by #danytechtuning |
12-11-2018, 08:21 AM | #13 |
Who Needs to KNOW?
i know on my last car without auto tinting, it was pain in the eye with rear view and side mirrors. Glad this car has it. And that car had much larger rear glass and side mirrors, which I sort of miss, side mirrors on camaro are jokingly small considering scale of the car.
ing for grip.
12-11-2018, 02:09 PM | #14 |
