11-18-2019, 08:49 PM | #1 |
Drives: 2010 camaro ss Join Date: Jun 2010
2 step for agp tt kit
Which 2 step are you guys using? My th400 will soon be back with a transbrake. I've hear of people using the lnc2000 or the msd. Which one is better or is there a difference?
11-19-2019, 09:30 PM | #2 |
Drives: All things Turbocharged Join Date: Dec 2010
The LNC-2000 is perfect. No idea about the MSD, might be fine.
11-20-2019, 01:13 AM | #3 |
I use the MSD with my Vortech. Works very well. By far the easiest install. And set up. But it just interrupts the coil packs. Will build enough boost for 90% of people running turbos. Most turbo setup will be fine with it.
But the LNC-2000 has the ability to build more boost and more control. |
11-20-2019, 10:55 AM | #4 |
Trouble_SM
Drives: 17' Summit White ZL1 Join Date: Jan 2015
LNC 2000 works best. I have had several buddies with bad experiences with their MSD 2 step.
11-25-2019, 07:59 AM | #5 |
Another Lingenfelter LNC 2000 fan here
12-02-2019, 10:47 PM | #6 |
Thanks guys. I got the lnc2000 in today
12-17-2019, 08:59 AM | #7 |
Drives: 10 SS A6 Huron TT Join Date: Oct 2016
What is the best way to hook these up to work on Auto 6l80 cars?
12-17-2019, 12:27 PM | #8 |
Drives: 2011 2SS Join Date: Mar 2015
I don’t know about for turbo cars but personally I have mine wired first to an on off switch, then to my brake pedal. So I have to first toggle the switch to on, then my brake lights have to be on for the 2 step to engage. That way it turns off right when I let off the brake for launches
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears |
12-17-2019, 04:08 PM | #9 | |
Drives: Camaro Join Date: Aug 2015
12-18-2019, 07:18 AM | #10 | |
Drives: 13 1LE 1SS/05 ZX10/02 Silverado/14 Join Date: Nov 2014
02 Stepside Silverado
05 ZX-10 13 1LE 14 Nightrod Special |
