03-27-2020, 05:16 AM | #1 |
Sold my mid runner FAST intake manifold
Decided to round out my radical build for a more radical manifold. I've been doing an intake manifold swap while my car was in the body shop.
Edelbrock Pro Flo XT LS3 I think it's a first for a 5th Gen. Clears the stock hood! Passenger wiper modded to clear. Just cut as shown and bend it up and then extend it back to the original length to get the sweep right. Testing I've seen has been on par with the Holley High Ram. Dyno results? 19rwhp gain and another 300rpm of rev. |
03-27-2020, 05:23 AM | #2 |
Dyno pull
https://youtu.be/HktDAomZYak |
03-27-2020, 05:24 AM | #3 |
Passenger wiper works great
https://youtu.be/kepn9polUug |
03-27-2020, 06:00 AM | #4 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
Awesome sauce!!!
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
03-27-2020, 08:21 AM | #5 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
I’ve been wondering if this would fit! That’s dope
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
03-30-2020, 01:18 PM | #6 |
Drives: 2023 Camaro ZL1 1LE Join Date: Feb 2016
Wow. Good gains. First I'm hearing of this intake.
2014 Camaro SS Spring Edition LSX440ci
LSX Block, MAST 305 Black Labels, Exceldyne Valves, Diamond Pistons, Callies Crank & Rods, Cam Motion Cam, Johnson 2116LSR Lifters, Comp XDA Pushrods, Jesel Rockers, Mamo MSD, NW 102, Roto-Fab CAI, FAST 65# Injectors, ZL1 Fuel Pump, Kooks 2" Headers, Corsa Sport 3" Catback, Z28 Shifter, ZR1 Clutch, Katech LW Flywheel, 1LE 3.91 Diff, LPW Diff Cover, BMR - 1.4" Springs, LCA's, Trailing Arms, Toe Rods, Sway Bars, End Links, Diff Bushings, and Tunnel Brace, Z28/1LE Strut Tower Brace, Improved Racing Oil Cooler 2023 Camaro ZL1 / 1LE Stock |
11-20-2020, 12:34 AM | #7 | |
YOLO Z/28
Drives: 2014 Z/28 Join Date: May 2016
2014 Red Hot Z/28, CTF car #39/69. HCI, Supercharged, boltons.
2006 SRM GTO, exhaust, VMR V701 wheels (SOLD) 2002 Bright Red Trans Am WS6: HCI, exhaust, tune, Konis, UMI sways, LCAs, Track bar, STB, 2" boxed steel SFCs (SOLD) |
11-20-2020, 03:19 AM | #8 |
It would be a tight fit but probably
11-20-2020, 10:27 AM | #9 |
YOLO Z/28
Thanks for the response. Ive been looking for an intake that would clear the stock hood and help power up top without breaking the bank. But mines an LS7 car so id have to use billet adapters.
11-23-2021, 10:32 AM | #10 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
Hey Bo, do you have any pics of the port work done to fit the 102mm TB?
I just ordered this manifold and nw103mm tb, and I'm just curious how much material needs to be removed. Thanks
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
11-26-2021, 12:32 PM | #11 |
Yeah I got a pic. Before and after.
11-26-2021, 01:48 PM | #12 |
Very clean looking Bo!! Nice job sir!!
12-06-2021, 10:25 AM | #13 |
Thanks Bo, I'll give this a try tonight. It probably wont look as pretty as yours though, lol.
12-06-2021, 04:40 PM | #14 |
Not bad for a rookie using a drill and some amazon bits.
