Homepage | Garage | Wiki | Register | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools |
![]() Drives: 2012 1LT/RS BLACK w NOS Join Date: Nov 2013
Smoke Cloud When I Floor It
Hey All,
Never really noticed this until last night - I was driving with a friend following me in his car behind me. I decided to "punch it" on an open stretch of roadway to see if he could keep up. Upon flooring it, i saw a cloud of blackish smoke come out of my exhaust behind me (from my rear view mirror), It was not thick smoke, I could see through it - but it was there. Kinda like a plume of exhaust gas. It lasted for about 1 -1/2 seconds when my pedal hit the floor. I never really noticed this before. My friend said it stunk like exhaust fumes from a bus. I had put a can of Royal Purple Max Clean Fuel System Cleaner in that tank of gas a day earlier. I'm wondering if this is normal, or if it was caused by the the fuel system cleaner, or if its a precursor to a bigger problem. Car seems to be running great! Never noticed this smoke before... Thoughts???
BBK CAI, Dynomax Ultra Flow Exhaust, Vitesse Throttle Controller, 3M Dark Tint, BMR Subframe Connectors, BMR Drive Shaft Tunnel Brace, Bosch Brakes, Ny-Trex Triple Threat System, Glowshift NOS Gauge, Innovate LC-2 Wideband AFR Gauge, GM Strut Tower Brace, Elite Engineering Catch Can, Heritage Grill, Custom LFX Emblems, BAFX Bluetooth OBDII Interface, Torque Pro Logging, Big Worm Graphix Spears & Stripes,Niche M117 Misano Wheels, MGP Caliper Covers
![]() Drives: 2013 Camaro v6 hot wheels edition Join Date: Sep 2014
Depends on how high of mileage you have but here is my 2 cents... 1) I noticed you don't have a catch can in your signature, so it could be that oil is being burned off from being dumped back into the engine so to speak.... 2) does it seem like your burning through oil? If your loosing oil with no a parent leaks I'd get it checked out.
Drop a gear and disappear
Catch can is my next mod. Will check my oil tomorrow to double check the level. Good advice…
![]() Drives: 2014 1LT w/RS Summit White Join Date: Aug 2015
black smoke would be the fuel to air mixture, no?
![]() Drives: 2013 Camaro 1LT Join Date: Jun 2015
Catch can.
Also, do you floor it often? Or are you a pet throttle only driver?
Elite catch can & clean side oil separator, Apex Scoop, CAI cold air intake, Vmax ported throttle body, TTT ported intake manifold, JacFab intake manifold spacer, Magnaflow cat back exhaust, Weld RT-S 17x5 f and 17x 9 r wheels, MT 28/6/17 f and M&H 275/50/17 r tires, TTT rear seat delete, Nitrous Outlet plate kit, 125hp jets.
#6 |
I floor it often. Heavy right foot.
Thread Tools | |
