09-03-2016, 03:05 PM | #1 |
Drives: Z06 wannabe Join Date: Feb 2015
JRE Race Scoop Install Photos
This is not a full on DIY, but it will give you another view of pictures and the difference the scoop should make.
ADM CAI Before Washer Bottle in front of Air Filter Washer Bottle View from side - Behind Front Wheel Well Washer Bottle Removed Front Air Dam, After cut for JRE scoop but before I removed the cutout piece. Have a flashlight in front of it for comparisons with After, below Air Dam after cutout removed....flashlight in same place as before picture. This should illustrate to you a fairly decent difference in airflow! View without the Flashlight, this is where JRE scoop mounts JRE Scoop installed (also remounted Washer fluid pump for the rotofab relocate. I moved it since this picture to get it out of the airflow. Front Bumper lower grill view. You can see the Scoop ready to grab air and shoot it to the air filter. Picture from above after install. And...... a quick shout out to the ABM SS/RS Mojave! Hope this was helpful.
Apex Focused
09-16-2018, 02:11 PM | #2 | |
Drives: 2013 WITHE SS Join Date: Jul 2015
