It don’t come easy.
Coil pack paint
Bored and looking for a little project this winter. Thinking about painting the coil packs. Any particular brand that’s better than others. What temp high heat paint should one go with? 500*, 1200*?
Thanks
When I painted anything that saw any kind of heat I used the VHT brand of "Hi-heat' enamel spray paint.
It don’t come easy.
Saw some of the VHT for plastic. Handles up to 200*. Went with some Duplicolor rated at 500*. Thanks for the info!
#4 | |
It don’t come easy.
Ready to go back on the engine. Took your advice Jewel and went with the VHT after regular engine paint wasn’t laying out well.
Only 15 degrees out in the garage today. We’ll let them cure up nice and hard and install them in spring. ![]()
#6 |
![]() Drives: 2013 Camaro SS Join Date: Jan 2020
Inspired me to give this a whirl on break…used VHT dark blue engine paint. My car is a 2013 BRM.
![]() Sent from my iPhone using Tapatalk
2013 2SS Blue Ray Metallic/Silver stripes, black Interior. Halo conversion, Diode Dynamics grill lighting, LED interior and fog lights. Sundown 8" DVC, Altrend 300.1 Amp, Handmade side-mount box. Soon to be BBK Headers and hi-flow cats.
#7 |
It don’t come easy.
Looks nice. Definitely dresses up the engine bay.
#8 | |
#9 | |
#10 |
#11 |
It don’t come easy.
Thank you sir!
#12 |
It don’t come easy.
After further thought, 20 degrees in the garage, out of the wind, was just fine to finish the job.
#13 | |
Man your engine is way cleaner than mine! Looks good Sent from my iPhone using Tapatalk
#14 |
Nice! Do you still run the engine cover? If not you should ditch the stock valve covers and coil pac brackets and get a set of Holly Billet ones. I have a set of the tall ones on my engine powder coated RJT to match the underhood theme, and the coil pacs bolt right onto them, no more ugly bracket. Plus it angles them some so they look better.
