Old 10-11-2013, 07:09 PM   #1
gen=5
gen=5's Avatar
Drives: 13 ZL1 vert blac fastlane/LPE 750
Help a member with the removal of the front splitter on a ZL1
I am trying to help out another member OVERPAR73 He wants to know if anyone has instructions or a link to step,by step instructions so he can remove his front ZL1 splitter so he can send it off to have it dipped. pls either post it here or just send him a PM. we looked and there didn't seem to be any info on it on you tube or google. thank you.
http://www.camaro5.com/forums/showthread.php?t=346589 CHECK OUT THE BUILDING OF MY RANCH FOR DISABLED VETS, COMPLETE WITH A GUN RANGE .
gen=5 is offline   Reply With Quote
Old 10-11-2013, 08:02 PM   #2
Deke736
COTW 12/3/12
Deke736's Avatar
Drives: 2012 Ashen Gray ZL1
I just replaced my splitter last weekend. Couldn't find any instructions but it's actually pretty simple. Assuming he knows how to remove the bumper, that's the first step. Then, remove all the Torx screws along the front edge. Then, remove the foam bumper support from the inside via the clips. Then there are 4 7mm screws that will be removed (the reason for removing the foam support is to access these screws). Then pop the 8 or so clips off around the splitter and it will slide free. I had mine replaced on and off in about 2 hours.
Here is a pic of the bumper without the splitter. You can see all the screws along the edge I am talking about:
Here is the splitter removed. The clips are also visible here:
Deke736 is offline   Reply With Quote
Old 10-11-2013, 09:18 PM   #3
OVERPAR73
2018 Garnet Red ZL1 conve
OVERPAR73's Avatar
Drives: 2013 & 2018 ZL1 vert
Thanks so much. That's what I was afraid of as far as having to pull the bumper.
Build Thread: 2018 ZL1 Vert Purchased (Overpar73)
OVERPAR73 is offline   Reply With Quote
Old 10-11-2013, 09:41 PM   #4
Deke736
COTW 12/3/12
Deke736's Avatar
The bumper is really not that bad. Take the tires off and the wheels liners out and it's really easy. It can be done without removing the wheels and liners, but it makes it much easier. I can remove the bumper in about 30 minutes now.
Old 10-15-2013, 08:44 PM   #5
gen=5
gen=5's Avatar
Glad to find you some help. thats what we are all here for..
Old 10-18-2013, 02:56 PM   #6
BlackZL1
BLACK ZL1
BlackZL1's Avatar
Drives: Dodge 3500, 2012 ZL1 VIN#371
While you have the front bumper off you can install those cool ass JDP halos and grill lighting...
BlackZL1 is offline   Reply With Quote
