05-12-2021, 09:59 AM | #1 |
Valve Spring
Hey all,
This past weekend I lost the outer valve spring. Unknowingly, the springs should be changed out every 20-25k miles which I never knew sadly. I have some new ones on the way now (https://www.motionraceworks.com/prod...ol660springkit) The outer spring is gone, however the valve is still held up with the smaller inner spring. I called Brian Tooley Racing about it and they said all is well due to the secondary inner spring, but I do need to change all the springs as these are about 25k miles now. Using a BTR Stage 4 turbo cam. Help wise, I ordered a hose from BTR so I can pressurize the cylinders. I'm not sure what end I need to buy to hook up to a compressor. Any ideas? Thanks in advance!
2010 Inferno Orange Metallic 2SS/RS - 6 Speed Manual
-BTR Stage 4 Cam, ID850 Injectors, E-85 Tuned, Corsa Xtreme Exhaust , Kooks 1 7/8 Headers, Melling Performance Oil Pump, ATI Super Damper, BMR Suspension: Sway Bars, Trailing Arms, 1” Lowering Springs, Differential Bushings, Rx Ported and Polished Throttle Body, VIS Racing Carbon Fiber Hood, Custom Painted - Body Kit, Entire Vehicle, ZL1 Addons Wicker Bill, MRR 20” Wheels, Powerstop Brakes, Koni SRT.T Shocks and Struts |
05-12-2021, 10:44 AM | #2 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
I'm not sure which hose end the BTR comes with, but with my hose I was able to use a spare air compressor fitting that came with my air compressor kit.
It's just your standard male fitting like these... https://www.globalindustrial.com/p/v...xoCDN0QAvD_BwE
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
05-12-2021, 10:58 AM | #3 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
I just rotated the motor so the piston is at top dead center... look in the spark plug hole and make sure you see the piston, then change the springs on that cylinder.
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
