Old 07-02-2014, 09:55 PM   #1
thabigdeuce
Thabigdeuce
thabigdeuce's Avatar
Drives: 2012 chevrolet Camaro 2LT/RS IBM
Miles per gallon question.
I've bought my 2LT/RS (V6 Auto) back in 2012 brand new, so far have no problem and just hit 40K miles today . It has been ~ 2.5 years and yet my mileage per gallon never seem to change. For the past years, I've only got 20.0 miles per gallon. I have made several road trip at about 200-400 miles distance back and forth...in which I've resetted both my MPG & Average speed.
But even after resetting the MPG, it does not seem to change at all. It will vary over the course of the ride; but over time, it will certainly go back down to 20 MPG. I do not know if I should be worried or is this normal?
I've been commuting; riding both in city and highway.
Avg speed 31.2 MPH
I have no mods, it is all stock!
Any advice please?
Thanks in advance.
Ines
2012 2LT/RS Imperial Blue metallic W/ Silver Stripes
2004 Tahoe BLK
thabigdeuce is offline   Reply With Quote
Old 07-02-2014, 09:58 PM   #2
Camarolover85
Drives: 2019 Dodge Challenger Scat Pack
Yikes. I average 26.8 in my 2LS, city and highway with an average around 31-32 as well and I have exhaust and intake. Sure you're not heavy on the gas? I usually speed up gradually and cruise along.
Camarolover85 is offline   Reply With Quote
Old 07-03-2014, 12:26 AM   #3
one~Bad~SS
one~Bad~SS's Avatar
Drives: 2011 2SS/RS CGM LS3
sounds like someone has a lead foot!
one~Bad~SS is offline   Reply With Quote
Old 07-03-2014, 12:32 AM   #4
Camero5
Hide! My wife's coming!
Camero5's Avatar
Drives: 2013 Chevrolet Camaro ZL1
Shit, I get 20MPG in my ZL1....... Sometimes, LOL.
I've had a V6 2LT and I was around 26-28
Upgraded to 2SS and was around 18-20 MPG Modded
Now with the ZL1, averaging 16MPG and on highway close to 20MPG and sometimes more.
2013 Camaro ZL1 Convertible CRT - 630 RWHP / 620 RWTQ - ADM Performance Built/Tuned - ZL-700 Package - LS9 CAM - Lingenfelter CNC Ported Heads - Stainless Power Headers
Camero5 is offline   Reply With Quote
Old 07-03-2014, 12:56 AM   #5
12Camaro12
12Camaro12's Avatar
Drives: 2016 Camaro 1ss
I average 18. But I drive almost 100% all city.
12Camaro12 is offline   Reply With Quote
Old 07-03-2014, 03:56 AM   #6
Baba
Baba's Avatar
Drives: 2011 Camaro 2LT RS Convertible
I'm pretty much in the same boat you are. I RARELY ever break 20 mpg. That's because whenever I do drive my 'vert, it's rarely over any great distance and a lot of stop-and-go suburban driving.
I'd suggest, however, to rely much less on your DIC and calculate your mileage manually or use an online calculator.
Here are some links to online calculators:
http://www.math.com/everyone/calcula...per-gallon.htm (you don't have to enter the "miles per day" unless you want a forecast of your monthly / yearly fuel expense).
http://www.calculator.net/gas-mileage-calculator.html
http://mpgtune.com/index.php
Prerequisite to make the math easier to calculate:
Always start with a full tank of gas, don't top it off, let the handle click when it's full and then begin calculating your mileage beginning with your next fill up. Always reset your trip odometer at every fill up so you know exactly how many miles you've driven, reset your DIC Avg. mpg and Avg. mph - do this while you're sitting at the pump. Then, you take the numbers home and plug them into the mpg calculator. I keep an online log which I find helpful in keeping track of mpg's and fuel expenses. http://mpgtune.com/vehicleDetails.php?carId=5547
Summit White
Black Leather
3 Pedals
Build Date: 06/27/2011
Purchased: 07/30/2011
Title Received: 08/15/2011
1984 Camaro (3rd Gen.): Traded: 1987
"Meet the new boss. Same as the old boss."
Baba is offline   Reply With Quote
Old 07-03-2014, 05:46 AM   #7
benji276289
benji276289's Avatar
Drives: 2021 Camaro 2SS1LE, 6 spd.man., Ora
Send a message via Skype™ to benji276289
There is no way you can compare what one car gets for mpg to another. Everyone has different driving habits and a different set of circumstances. In order to compare, you would have to be testing two cars yourself for a period of time. MPGs are all over the board otherwise.
benji276289 is offline   Reply With Quote
Old 07-03-2014, 09:46 AM   #8
FaytalsCamaro
Distributor of Liquor
FaytalsCamaro's Avatar
Drives: My Wife Crazy
Your mpg is fine...it all depends on if you have any mods, how you drive, where you drive etc. You could be worse off. I AVERAGE 12.5 mpg
FaytalsCamaro is offline   Reply With Quote
Old 07-03-2014, 12:01 PM   #9
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
Agreed, I get 22-23 mpg hwy, and I have supercharger/tune/headers.....and a lead foot.
Old 07-03-2014, 12:29 PM   #10
Evergreen6
Drives: 2023 Camaro 1SS
There's no good way to answer this. There are too many factors that could be influencing your numbers. If your tires are set at optimal pressure and there are no other mechanical issues, I wouldn't be too alarmed.
My average speed is right around 47mph and I average 27.0mpg. 91% of my commute by distance is open freeway posted at 60-70mph. Theoretically I should be getting better mileage but there are several factors making that unobtainable. Most of that freeway is rolling terrain and has an elevation gain depending on the direction. The corridor is known for strong winds, and in the afternoon I'm usually running the A/C. My tires are checked/filled to optimal pressure and I maintain constant speeds and throttle where possible.
Your results are probably fine; Think about what factors might influence less than stellar or advertised MPG and try to factor those in. Your MPG numbers aren't likely to be random or because of bad luck.
Evergreen6 is offline   Reply With Quote
Old 07-03-2014, 12:36 PM   #11
Dupree878
Dupree878's Avatar
Drives: '13 Dusk Edition 2SS/RS M6
That's worse than my SS
Dupree878 is offline   Reply With Quote
Old 07-03-2014, 12:42 PM   #12
JTruck
JTruck's Avatar
Drives: 2014 Camaro 1LT/RS
Taking a picture at 100mph...
Detailing is an involuntary obsession.
JTruck is offline   Reply With Quote
Old 07-03-2014, 01:02 PM   #13
keving2873
keving2873's Avatar
Drives: 2011 Camaro 2SS RS
At least it wasn't a selfie.... lol.
2023 Black ZL1 **Awaiting Allocation**
476whp 455trq / Tuned by Tom Wong
CAI Intake with ADM Scoop, Borla ATAK cat-back, ARH 1 7/8 Headers and HF Cats
Custom Comp Cam 231/234 114LSA 617/598 lift, Katech timing chain
Apex Catch-can
VMAX Ported Throttle Body
20" Niche Essen's wrapped in Michelin PSS 315/295
keving2873 is offline   Reply With Quote
Old 07-03-2014, 01:18 PM   #14
luis550
Drives: 2013 2lt
i usually call BS on anyone getting more than 25 in the City.
luis550 is offline   Reply With Quote
